Allergic to my tractor?
   / Allergic to my tractor? #1
vicar
Northeast Connecticut
BX-24
I have been lurking on this great board since last summer, though this is my first post. Partly based on what I read here, I bought a BX24 in August and love it. I have about 85 hours on it so far, mostly backhoe pulling stumps, trenching, grading a new small pasture for my wife's sheep and recently snow removal with FEL and backblade. One problem: I have had sinus problems since last summer (for the first time in my 50+ years) and I have finally made/ admitted the connection that I am allergic to the diesel exhaust. I can get my sinuses reasonably cleared up, and then a couple of hours of seat time and I sound like I have a marble stuck in my nose.
I use ULSD Diesel from the pump, and have even tried changing brands to see if any burn cleaner. I think that has made some slight improvement, but there is still a problem. I have about 100 hours of projects lined up once winter is past so I need some help here. I can't imagine having to get rid of this toy--I mean tool--now that I have seen what it can do, but I can't imagine walking around with sinus problems, living on Nasonex for the rest of my life either.
I remember someone posting about adding an exhaust pipe to the rear, but I don't see how that would help me since so much of my use is with the backhoe. (Why did they place the exhaust pipe so it blows right in the driver's face anyway???) I see an additive advertised in TSC catalog that promises cleaner burning and less pollutants, but is that any different than what i am using now to prevent gelling? Any help greatly appreciated.
   / Allergic to my tractor? #2
Air conditioned cab with filter?
   / Allergic to my tractor? #3
I'm puzzled- I'm very sensitive to a wide variety of airborne irritants and my BX24 doesn't bother me at all. I don't even smell it when running and I would for sure if there was any exhaust to smell.
You mentioned the exhaust blows in your face...are you sure all the exhaust system is intact and correct? Mine exits left front and the radiator fan pushes air forward from the rear of the engine compartment helping dissipate the exhaust.
   / Allergic to my tractor? #4
I would think cab, but since you apparently already have a jewel, why not use one of the old cutout valves that hotrodders used in history stories. Simply add a rear exhaust system, with a diverter valve to channel it rearward. Since you have a backhoe, while your at it, add another exhaust pipe running to the front and out the side so you can channel the exhaust to the front. Make sure it isn't near the radiator so it can't get sucked in with the radiator fan. Probably several hundred dollars worth of additions in pipes and valves, but a trip to the doctor or medications can eat that up in no time, not to even consider your comfort and future health.
David from jax
   / Allergic to my tractor? #5
On the BX24 the radiator is under the steering wheel and the air is drawn through from around the operators legs and blown FORWARD.
Skyco,
As far as I can tell exhaust is intact. It comes out where you say, is rarely/never visible except for a puff of black smoke when I start up. I think whatever help the fan gives in pushing smoke forward (I never thought of that) is overcome by air currents when driving forward (Like when grading or plowing my drive), or just by the breeze on my hilltop. I notice that there are black smoke/ smudge stains on the loader arms by the exhaust. Is that typical for BX?
I really have been in denial that this is the cause of my sinusl problem, but I'm pretty sure it is. The onset came at the same time as the tractor, and it seems to get worse within 24-36 hours of use. A cab would be nice, but is that even possible on a BX? It's hard enough to get to the BH as it is with having to reverse the seat. I can't imagine it with some kind of door or curtain in the way. Or am I missing something?
David, Where would i even begin researching how to put pipes on?
   / Allergic to my tractor? #7
Soot staining is normal. I have some on the hood around the outlet. Rarely do I smell the exhaust except when starting it in the garage. Is it possible that when digging etc you are kicking up some allergin that hasn't been kicked up as much before?
I really don't know other than claritin etc before starting a project.
   / Allergic to my tractor? #8
Is it possible now that you have the tractor you are spending more time and longer periods of time outside and normal outdoor irritants are really the issue?
As for the exhaust you would need to find a way to route it as far away from you as possible... which may be hard on such a small tractor.
Charles
   / Allergic to my tractor? #9
Not sure if this relates, but I had to give up running a 2 cycle snow blower from the exhaust fumes. Once upon a time in my life I worked for a snow removal contractor running one of those little Toro's up and down sidewalks - you know, it's not about the money, but the glory - :rolleyes: - anyway, I would be hung over with headaches and nausea for a good 48 hours afterwards, no amount of tinkering with the fuel or oil seemed to help much. When I got my diesel tractor I was quite concerned of a repeat, but so far so good.
Hope you find a solution, keep us posted!
   / Allergic to my tractor? #10
One of the guys I work with has a sinus problem when around Diesel smoke. Apparently always has... He has a Terramite with a gas engine that doesn't bother him. He has a Deutz with a Diesel that, as he puts it, "Tears him up!" You might try one of the good respirator masks. Other than that, I've few suggestions.
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
46006 (A51694)
46006 (A51694)
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Electric Mobility Scooter (A51694)
Electric Mobility...
