Aldo Biagioli Implements - better pics
   / Aldo Biagioli Implements - better pics #1
vdeal
WV
Case 1290, BCS 720
For those of you who want to see better pics of the Aldo Biagioli implements than the low res ones on the Earth Tools site you can find them on the manufacturers website. This PDF document has all of their soil working implements for 2 wheel tractors with pretty decent photos.
I believe Joel carries most of them.
   / Aldo Biagioli Implements - better pics #4
Does anyone have experience with a sub soiler? How well does it work even with wheel weights?
   / Aldo Biagioli Implements - better pics #5
Hi! Some years ago I make one and try it. For first 8 in. no problem but for more. Hardpan is very hard to penetrate need lot of weight then wheels spins. Too hard.
A neighbour farmer use a John Deere 130 hp four wheels drive over 5 tons for pull four narrow chisels about 18-24 in. deep or about 30 hp and near 1.5 ton by chisel.
Good luck Oldmech
   / Aldo Biagioli Implements - better pics #6
I a made subsoiler the shank is too long, will have to fix it. I will post pics later.
   / Aldo Biagioli Implements - better pics #7
These are much nicer pics - thanks!
I'm not particularly thrilled with the Aldo Biagioli potato digger I have (hard to keep straight, and cuts too many potatoes), so I am not even considering their other plows, subsoilers, harrows, and ridgers. However, since I have the 'tool carrier' part from the potato plow, I am considering a bed shaper and perhaps one of the cultivator tool bars with some chisels, sweeps and gauge wheels. Does anyone use these? Any comments on their utility would be welcome.
-otus
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2025 Mower King SSBM72 (A50123)
2025 Mower King...
Wacker Neuson DT08 (A50123)
Wacker Neuson DT08...
2005 Dodge RAM 1500 (A50123)
2005 Dodge RAM...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
