AlanB
Elite Member
Anyway, if you go way back here....
http://www.tractorbynet.com/forums/projects/95654-al-bs-house-rework-3.html?highlight=house+rework
Scroll down a couple posts, and you see where I was pondering what to do with my well house.
Finally gotten around to where it is on the do it list now.
Hanni came up with what I feel is the best idea, and that is that we will make it look like a wishing well, but first, as with so many other things around my house, I have to make it work first. And as with so many other things around my house as well, it is not how it appears when I first look at it.
I did not get the "before" shots I should have, but I thought my pump was sitting on a mud floor and that the well head pipe was cut off lower then the mud of the well house floor. The top seal was crooked and did not fit in place and the well casing was cut on about a 20 degree angle.
Initial plan was to remove pump, pull up lines, remove well pipes, dig out bottom to below well casing, cut casing square, fill bottom with rock, reset pump on clean gravel / rock, fill in cinder blocks with concrete etc.
So, real world is cut out pump and remove and go to start digging out bottom only to realize that bottom of hole is concrete.
Then realize that bottom of lowest part of angled well casing is below concrete surface
Measure pipe, yep, 6" no problem. Get a 12" peice of 6" pipe and add too it..... Well get a peice of 6" pipe and realize that it is bigger then what is in the ground (slightly) then wonder which is correct for the well cap seal. Fortunately, what I have is correct and fortunately I have a welder
So, chip out concrete around pipe enough to lay in hole and weld, then weld new pipe in reaching down through pipe to weld and laying upside down in hole to weld the base................... No pics, not a happy guy.
Then put in some tapcons around base, and form a little raised area to keep groundwater away from well head.
Then form up a little pour and pour and then fill up cinder block walls so snakes are not quite so welcome.
Use the extra mortar mix laying around the house from when SWMBO does landscaping jobs, just add gravel as filler.
Tractor was used to haul the concrete back and forth from the mixer location to the well house.
Oh, and also in my "house that China Built" theme of things, man, this concrete vibrator is just hard to beat when it comes to doing work like this.
