Alabama Amateur Farmer & Mechanic
   / Alabama Amateur Farmer & Mechanic #1
Dan370
John Deere 1050 (1987)
I got an old John Deere 1050 (1987) that ran hot on me while i was gone for awhile. It was smoking real dark black smoke. I changed the oil & put water back in the radiator. It seemed to crank work ok. I felt like maybe it was ok. I fired it up to plow my garden and a loud clacking noise (like a rod knocking?) with black smoke started and I had no real power.
This is my second summer with a tractor and gardening. I have 2 questions.
1. What is wrong in your opinion (motor rebuild replacement)?
2. If I'm looking at a huge cost, then what is my best and cheapest option to replace it? I'm 71 yrs old and retired. I did replace the clutch in it about a year ago and that was a nightmare!
   / Alabama Amateur Farmer & Mechanic #2
Sounds like you are looking at a motor rebuild. The easiest thing would be to find another running 1050 and save your current one for parts.
Exactly what I was thinking. Thanks for your input.
   / Alabama Amateur Farmer & Mechanic #4
I'm not familiar with that tractor, or that engine, but I have rebuilt the Cummins 6 cylinder engine on my dozer. It was all done in frame. I removed the head and the oil pan, pulled the pistons, and then the sleeves. Overall, it was more intimidating thinking about doing it then the actual process of doing it. I don't want to do it again, but cost savings of doing it myself was significant.
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
205113 (A52706)
205113 (A52706)
20X30 ALL-STEEL CARPORT W/ ENCLOSED SIDEWALLS (A53843)
20X30 ALL-STEEL...
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
