aircompressor on windmill
/ aircompressor on windmill #1
leaddog
West Michigan
Century 3045
I have a windmill next to my lake and have thought about using it to run some sort of aircompresser to areate the lake in the winter. it is an areomotor head and it works. I'm going to hook it up to a pump also just for show.
I bought it at a yardsale and got it up last fall. It's a 50 footer with a 8ft head and runs good. Its at least 75 years old and sure looks nice here in my yard
Has anyone hooked up one to pump air to ariate a lake and what do I need to do.
Thanks
Leaddog
/ aircompressor on windmill #2
In some areas where dugouts are used for a water supply windmill areators are a quite common.
Don't have any details on one but a search should turn up all the information you need.
Egon
I've searched and have found alot of info but what I'm looking for is how to make or use a compressor for my aeromotor windmill. It uses the rod that goes up and down to run the pump and I would like to be able to unhook the rod from the pump and hook it up to some type of air pump. I have thought of maybe using a air cyl or something of that type. Has anyone done such a thing?
/ aircompressor on windmill #5
Sounds like youre thinking of something like an old time plunger type tire pump. Wouldn't be hard to make.
Egon
Ya that is sort of what I was thinking but I was wondering if anyone has done it so I could get a idea of how large a cyl I could use and if they had any prob. It seems like it would work but maybe it wouldn't supply enough volume or press to flow though a stone diffusur. also was wondering if it would freeze up. Don't want to spend alot of time if it has been done and don't work.
Thanks
Leaddog
/ aircompressor on windmill #7
The Windmill dugout arateors I was thinking about were used in Northern Alberta so they may not freeze.
Egon
/ aircompressor on windmill #8
Northern Tool has a windmill aeriator (where is spellchecker when you need it) listed in their catalogue. You might start there, find out who makes it for them and see what's involved. From my point of view (total ignorance of the subject) it doesn't seem as if would be too hard a project and since they are advertised, they obviously work.
/ aircompressor on windmill #9
By the way, I forgot to ask, "How did you move a 50' windmill with an 8" rotor?"
/ aircompressor on windmill #10
Try looking at Koenders, I have their electric model but their windmill is the same from the compressor out. You would need to get the compressor and mount it on the windmill framing. It works on a diaphram system, won't freeze in winter. They aerate from the pond bottom through an air stone. You would run a 1/2" black hose out to the stone from the windmill. I sunk the hose on mine using a brick every 10 feet. Ran it a total of 175 feet out. They will keep about a 15 foot opening in the ice all winter, providing the breeze keeps up.
Mike
Koenders is at http://www.koenderswindmills.ca/
As to how I mover it, it wasn't to bad. I had a contractor bring out there boom truck. I had it all ready to drop and they hooked onto it and just layed it down. Cost me 120 bucks for an hr which included the drive out and back. Then I unbolted it in half and with my tractor fel I loaded it on my trailer. two trips and I had it home.Then I painted and inspected it and got it ready to put in the ground. Because it had had a pumphouse on it and had been struck by lightning and burnt I put the bottem 4ft into the ground as it was warped. I used a bh to dig 4 holes and because I couldn't get the boom truck I rented a extenda forklift and put it up that way. I buried a 24in tile with a 4in pvc pipe running out into the lake and when I get the pump running I'll pump out of the lake for my flowers.
This is my view out of my east window in the mornings
I looked at these but it looks like the compresser connects to the head(turbin). My head and gearbox is ok and I don't want to change that part. It has a jack shaft that runs down to the bottem of the windmill and goes up and down about 5 in. I might be able to use their commpresser but I can't tell from their diagrams. Plus I am trying to get by on the cheap and not buy any thing to costly. I go to alot of auctions and can pick up alot of cyls and such if I know what I'm looking for
Thanks
/ aircompressor on windmill #13
LeadDog.. maybe check out these sites.. you can order parts for your windmill or tower. I bought an old "Chicago AeroMotor" windmill too.. currently sitting inside the barn. A rebuilt 8' head is around $3K.. and that's w/out the 50' tower.
I'm looking at getting another well drilled(for livestock) and set the windmill up there.
http://www.aermotorwindmill.com/
I've emailed w/ the woman Ellan on this site.. she knows a lot about windmills.. she is very nice and is willing to answer questions.
http://www.windmills.net/
"I put the bottem 4ft into the ground as it was warped. I used a bh to dig 4 holes"
I was wondering if you set this in concrete? Hope you find what your looking for! Ken
/ aircompressor on windmill #14
You might try using an old 2-4 hp gas motor, the horizontal type. Pull off the carb., gas tank, muffler and all other parts no longer needed. Make sure that you do have good rings, so it will hold up and pump air. Replace the muffler with some threaded galvanized pipe, so you will be able to attach an airhose. Attach an air filter where your carb. use to be and fill the crankcase with a good oil. Leave the sparkplug in or replace with a plug. On the output shaft, attach a large wheel, disk or pulley and on the outside edge drill a hole so you can attach the pitman arm (connecting rod from windmill). You can raise the motor and put a larger drive wheel on the motor/compressor, if needed (think back to the basic fulcrums and levers). It will depend on how much power your wind motor puts out.
This will work and has an added bonus of being relatively cheap. A little thinking, parts and some elbow grease should get you in operation.
/ aircompressor on windmill #15
How about bulding yourself a bellows type air pump like they used to use on forges. Two pieces of round wood about 12 to 18 inches in diameter, a piece heavy rubber intertube (tractor or semi) glued and fastened around the two pieces, an intake valve on top and an exhuast valve on bottom. Glue a piece of PVC pipe to the discharge side to hook your aeriator tube too. Mount the bottom to the side leg of the windmill at the desired hieght and move your pump rod over too it when you want to use it.
Redneck Engineering INC.
/forums/images/graemlins/grin.gif
You just might have something there. thanks
leaddog /forums/images/graemlins/smile.gif
John Deere 148 Loader with Brackets (A65640)
John Deere 148...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
Grain Drill Hopper (A64127)
Grain Drill Hopper...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
