Air tool connection question
/ Air tool connection question #1
Trev
Platinum Member
Williamson, NY (near Rochester)
Currently tractor-less
I just found a nice little Coleman Cut-Off Tool which I thought would be handy for those times when the tiller picks up tough vines or wire and wraps it up tight. Just go in with this and cut the stuff out of there. I think I can also put a small grinder wheel on it for sharpening blades.. but it might take a bit of work.
My question, though, relates to something that is said in the instruction that came with this air tool. It says <font color=red>"NEVER connect quick change couplings directly to the tool or air inlet. Use a leader hose."</font color=red>
First I have heard of this. They show a diagram with a short length of hose connected to the tool one on end and to a quick change coupling on the other. It looks, from the diagram, to be about a foot long.
I connected the quick couple directly to my other tools, and never had a problem, and never heard of using a small leader hose. They don't explain here why this is so important. Anybody have any ideas about this? In the case of this small tool, I can see how the leader hose might be helpful, in that it might allow me greater maneuverablility in tight spots, but for something like an air wrench what difference would this make?
TIA for any thoughts!
Bob
/ Air tool connection question #2
all the documentation that I've seen seems to relate to flexibility.. When you put the quick-connector end directly into the tool, then the flexibility of the hose doesn;t start until a little bit after the end of the male connector .... what, a couple of inches or more out from the tool.
Using a short length of hose before the quick coupler gives you flexibility much closer to the unit.
I'd also think you'd have much less chance of accidently de-coupling if the quick-connect were much further away from your hands.
I did the "one foot hose" thing with most of my air tools, but it sure makes stogae in the toolchest much more difficult.
pete
Thanks, Pete. Makes sense to me. A buddy says he has one I can have, so I'll try it on this cutting tool. This is a case where the added flexibility might really be worthwhile.
Appreciate the help!
/ Air tool connection question #4
Maybe the tool is weak at the connection spot, and the leader relieves some of the torque on that part of the tool. With the length of the quick coupler, etc. and the fact it is pretty rigid, there may just be too much leverage applied to the tool base that it cannot handle. And as you say, the short leader will allow for more and easier movement.
I have not heard of it before either, and don't use that approach on my other tools. Will look into it though. Thanks for bringing it to our attention.
/ Air tool connection question #5
A whip is used to minimize the effect of vibration and shock on the quick-coupler.
Edit: I've never used one on my tools and never had problems.
/ Air tool connection question #6
What kind of "blade" does this cut off tool have? Mine is an abrasive wheel. Good for cutting steel, but not so good for cutting vine. You'd want some kind of steel saw blade. Of course unless you wrap a wire up.
The whip on the air tools is a best practice. My experience is that not using one is good enough. I am an occasional user, and have not had any problems.
One thing that is really nice is the swivel connector, lets the air hose go the direction it wants to. Nice for tight spots (under the hood of the car / tractor etc.)
<font color=blue>What kind of "blade" does this cut off tool have? Mine is an abrasive wheel. Good for cutting steel, but not so good for cutting vine. You'd want some kind of steel saw blade. Of course unless you wrap a wire up.</font color=blue>
oopsey. /w3tcompact/icons/blush.gif I kind of figured if it would cut steel it would go through a vine like the proverbial hot knife through butter. I guess that, as is often the case, I figured wrong? I'm sure I can find some kind of steel blade for it. The guy who sold it to me helped me cob together a grinder wheel for it (unusual, in my experience, to find someone so helpful at Chase-Pitkin) so probably I can do the same with other types of blades. He told me to just keep the box intact so I could return it if it didn't work out for my needs. But for $29 or so, having something to cut metal might be worth it anyway. Especially if I have to shorten my PTO shafts to install the over-running clutch that my wife says just arrived today. /w3tcompact/icons/smile.gif
A buddy at work says he has one of those swivel whips that he isn't using, so he suggested we "store it" at my house. So that part is covered.
Thanks for all the advice, folks!
/ Air tool connection question #8
Bob, be careful with that thing. No doubt you'll find it handy, but it's got to be one of the most dangerous air tools you can use.
<font color=blue>Bob, be careful with that thing. No doubt you'll find it handy, but it's got to be one of the most dangerous air tools you can use.</font color=blue>
Well, I bought eye protection and have good gloves. What kinds of things are apt to happen? I can imagine the cutting wheel breaking and sending out shrapnel, but the wheel itself seems made of pretty light material.. so I assume eye protection is the biggy?
/ Air tool connection question #10
Bob, one of the things I find with it is that it will literally "jump" in your hand when you first hit the switch. When cutting the vines, I would be careful as it is a metal cutoff saw and depending on where you are cutting the vines under your tiller, you may cut into or scar something that you may not want to scar.
I find mine quite useful.
/ Air tool connection question #11
Eye protection is important for sure - but the concern for me would be getting a very nasty cut - the kind that leaves you with parts missing. The disk can grab causing you to lose your grip, or the tool can go scuttling across the surface you're working on.
Use both hands when you can, and keep the free hand out of the way when you can't.
/ Air tool connection question #12
<font color=blue>oopsey. I kind of figured if it would cut steel it would go through a vine like the proverbial hot knife through butter. I guess that, as is often the case, I figured wrong?</font color=blue>
It will cut thru wood, just not as good as a saw blade.
Mind the other advice regarding saftey. Have a firm grip on it when you pull the trigger, it has a lot of torque & the body (as opposed to the spinning wheel) will rotate when you start it up.
Enjoy, more power (insert tim allen grunts here)
Well, as it turned out, the cut off tool I bough was defective, and they didn't have any others in stock. So instead I got an air-powered 3/8 inch drive air drill. The guy helped me rig up a cutting wheel for this, and I'm sure I can find other wheels.. perhaps from Dremel, to do about anything I want. At least I hope so. We'll see how this works out for general purpose use.
At least this one has a normal handle like most hand drills, so that problem of it turning in my hand should be minimized. Whether this will do what I want remains to be seen, but at least I have a nice air drill now. /w3tcompact/icons/smile.gif That is, assuming this one isn't defective also. /w3tcompact/icons/hmm.gif
Thanks for all the pointers, folks!
/ Air tool connection question #14
I hope this isn't to late but i'm a diemaker at work and put
a 6' soft rubber hose from grinder to quick-connect this way for
grinding overhead in a large press this set-up is lighter and more flexible.
More access to tight areas and can use on bench w/o getting big airline out.
This is nice set-up on drills and blow-guns too.
<font color=blue>I hope this isn't to late...</font color=blue>
NEVER too late for good advice! /w3tcompact/icons/smile.gif
Thanks.. I did the mod to my air drill, and it made a big difference in ease of use and ability to access. I don't see it as needed yet for some of my other tools, but I can always change my mind later. In the meantime, this was a good change. Thanks, everybody...
Bob
/ Air tool connection question #16
The leader hose is protection for your main hose. If you use it a lot, the constant flexing of the hose at the tool will ultimately lead to failure of the hose near the end. It would be easier and cheaper to replace a leader hose than the main hose. That said, I don't use leader hoses either. /w3tcompact/icons/smile.gif But I don't use mine all that much anyhow.
/ Air tool connection question #17
Trev,
As mentioned, the swivel at the end of the leader hose or just prior to the quick connect also helps reduce hose wear.
PJ
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
2019 Nissan Leaf 4 Door Hatchback (A66738)
2019 Nissan Leaf 4...
CAT 963C GP Bucket (A68134)
CAT 963C GP Bucket...
2020 KOMATSU PC360LC-11 EXCAVATOR (A65056)
2020 KOMATSU...
