Air tank on tractor.
   / Air tank on tractor. #21
montanaman said:
You want to use the York compressors because they contain oil in the compressor while many styles have the oil traveling in the system. Use the type without a sump and it won't live long.
I have used a saden style compressor for several years now. the solution that i have for the oiling issue is putting a siphon oiler on the inlet of the compressor and an oil seperator on the outlet. i found some at harbor freight that has the same bowl. when the oiler is empty and the seperator is full i just swap them.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58216)
8 TOOTHED BUCKET...
Heavy Duty 4-Way Lug Wrench (A57454)
Heavy Duty 4-Way...
36in Digging Tooth Bucket Excavator Attachment (A56857)
36in Digging Tooth...
2016 Sun Coastal 16' Cargo Trailer (A57148)
2016 Sun Coastal...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A58375)
UNUSED CFG...
