Tires air pressure
/ air pressure #1
slammer3364
Bronze Member
Jinma 284
anyone know the air pressure on Jinma 284 front and rear Thanks Slammer:)
/ air pressure #2
Max air pressure should be listed on the tires although you may not wish to put maximum pressure in the tires especially on the rear. I find that rear tires pretty much work for all sizes with around 12 PSI. You want just a bit of squat/giveto the tire when you have the heaviest piece of equipment on it. This gives the smoothest ride and best traction.
Fronts take a lot more especially if you are running a FEL. For my fronts with FEL, I usually run about 10 PSI below max pressure. That allows me to carry max load without fear of running the tire off the rim.
/ air pressure #3
The pressure on the chinese tires will also be in BAR so you need to convert it to PSI:)
1991 BRENNER TANK TRAILER (A67714)
1991 BRENNER TANK...
Engine knock
Engine knock
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
2005 STERLING LT9500 SERIES HYDROVAC (A67714)
2005 STERLING...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
