AIR LOCK ???
/ AIR LOCK ??? #1
rj100
Roanoke, West Virginia
SC2450 Cub Cadet/Yanmar
I installed two new lines to the cylinder that curls the bucket on the bucket on my sc2450 cub - yanmar tractor. Now I can't get the bucket to work, all other controls work fine. Would appreciate some help. Thanks
/ AIR LOCK ??? #2
If you have quick disconnects in the lines make 100% sure they are both fully connected.
If the bucket fully dumped and staying there? If yes you may have crossed the two lines. With a regenerative dump system it would dump but not curl.
If neither of these and system is full of oil the cylinders should move. They may be slow and jerky until air is removed but still should move.
/ AIR LOCK ??? #3
Ditto what oldnslo stated. Air will not lock hyd operation but merely slow down the function.
/ AIR LOCK ???
Hey guys , I figured out the problem. When the hose got made they double crimped one end of the hose and closed the hose off. No fluid could get through the hose. They made a new hose and all works fine. Thanks guys all the answers.
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
New/Unused Landhonor Quick Attach Power Rake (A61166)
New/Unused...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A61165)
2022 Kaufman...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A61568)
1999 Sterling...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
