Air in water lines
   / Air in water lines #1
Jerome
Elmvale Ontario Canada
Kubota L245dt
Lately I have been gettin air in the water lines in my house when I first turn on the taps. I am on a well and the pressure tank is fine any other ideas??
thanks
   / Air in water lines #2
Maybe some information about the well.
Are you sure it is air?:D
250 foot deep submerasable pump at 150 foot mark with a slight flow in spring. if not air what?
   / Air in water lines #4
Is your presure switch in an easy place to listen for it to cycle? If so first confirm it does not cycle when you are not using water. Turn the water on and watch when the pump comes on and off. Typical 30psi-on and 55psi-off. This time, turn on the water so you can get the psi down close to point where the pump will turn on. Let it set for ten min. This will determine if you have a leak any place.
Second, check your tank blader presure. Mine is at 32 psi. Well pumps need the air blader because water is not compressable. Low blader pressure will cause quick on-off pump cycles. Good presure will have long cycles.
Last, are running it dry? Why is the pump so far off the bottom? Around here, 20-30' off the bottom is normal.
   / Air in water lines #5
Yesterday I finally had a whole water treatment system put in because I had "air " in the lines. Turned out to be a gas, methane infact. I know because it was flamable. It would come and go, new construction we moved in mid feb and got bad air in the lines 4 times or so, lasting a week to two. I can provide a ton more info if needed.
   / Air in water lines #6
vaj
Looks like maybe you have a solution to high heating bills. Find a way to capture the methane and store it for use during the cold NY Winter.
Farwell
   / Air in water lines #7
Methane is quite common in water wells in some areas and very often mistaken for " air "
   / Air in water lines #8
Quite a few by hand well diggers died in Michigan back in the old days from pockets of natural gas that were opened while digging.
Farwell
I don't think it is methane tha well is 20 years old and no one else around has ever had or heard of the problem. the pump is so far off the bottom because there is at least 100 feet of water on top of it. I have had the water tested and everything came back 0. open to other suggestions.
   / Air in water lines #10
What is the timeframe that the air takes to build up in the lines? Is it overnight? Couple hours? etc?
How do you know that the well isn't running dry? Have you done a flow test and ran it solid for a while?
Do you have a backflow prevention device plumbed after the pressure tank? Maybe it is sticking and a slow leak or running faucet/ toilet isn't enough to open it up so it makes a void? (not likely but just a guess).
Also, it could be a faulty pressure switch. I have seen that when the pressure switch is defective it wont kick in in time and in a presssure tank with a bladder you get just air or nothing. Does it sound like air or is there just an absence of water?
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
UNUSED Safety Traffic Cones (A53117)
UNUSED Safety...
