Or the well level has dropped to very near the pickup level. Even a submersed pump will entrain air then.Continuously sucking air could only be from a leaking suction line.
Yes. Dont they usually equip that type with an air injector to prevent it becoming waterlogged? Could that device malfunction to an overactice state nearly filling the tank with air.It seems it is a 42gal tank with NO bladder.
Quick Tanks 51 x 2 in. 75 psi Galvanized Pump Tank Vertical - Q42VSQ - Ferguson
I checked pressure on the valve stem with a tire gage and didn't get any reading. The pressure switch comes on at about 32 lbs and off at 54 lbs. I did not see the valve stem do anything when it turned off. The water level is about 3 or 4 inches above the inlet which is maybe a quarter of the tank. The lines in the house are hammering and spitting air.
Thank you for all your help
Vern
Vern
