Air in Hydraulic System
   / Air in Hydraulic System #1
P hut
New Holland TC33D
Air in Hydraulic System 2002 New Holland TC33DA
I have New Holland TC33D that I replaced a hydraulic line on the loader. Now when I use front loader or 3 point hitch it moves very jerky and slow.I am pretty sure this is due to air the lines. Will this work it's way out or is there a place to bleed the system.
   / Air in Hydraulic System #2
Hydraulic cylinders will self bleed if you hold the lever long enough to fully stroke the cylinder plus a few seconds to push the air out. I'd use the same procedure on the 3-point to expel the air. Might have to do it a few times to work all of it out of the system. Have checked the oil level and replaced any oil that was lost?
Kim
Thanks, is there any chance of hurting the hydraulic pump? The sytem makes a squealing sound during operation. There were no problems before hose replacement.
   / Air in Hydraulic System #4
The squealing sound is probably your pressure relief valve (if it happens when you move the control lever). I would reset all quick disconnects and check the fluid level before doing anything else.
Aaron Z
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2005 International 4300 Bucket Truck (A52377)
2005 International...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
