Air in Hydraulic System
/ Air in Hydraulic System #1
P hut
New Holland TC33D
Air in Hydraulic System 2002 New Holland TC33DA
I have New Holland TC33D that I replaced a hydraulic line on the loader. Now when I use front loader or 3 point hitch it moves very jerky and slow.I am pretty sure this is due to air the lines. Will this work it's way out or is there a place to bleed the system.
/ Air in Hydraulic System #2
Hydraulic cylinders will self bleed if you hold the lever long enough to fully stroke the cylinder plus a few seconds to push the air out. I'd use the same procedure on the 3-point to expel the air. Might have to do it a few times to work all of it out of the system. Have checked the oil level and replaced any oil that was lost?
Kim
Thanks, is there any chance of hurting the hydraulic pump? The sytem makes a squealing sound during operation. There were no problems before hose replacement.
/ Air in Hydraulic System #4
The squealing sound is probably your pressure relief valve (if it happens when you move the control lever). I would reset all quick disconnects and check the fluid level before doing anything else.
Aaron Z
(UNUSED) REDDICK OFFSET DITCHER, 3PT (A64278)
(UNUSED) REDDICK...
2016 CATERPILLAR 311FL RR EXCAVATOR (A65053)
2016 CATERPILLAR...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
CATERPILLAR 420E IT BACKHOE (A65053)
CATERPILLAR 420E...
2004 IC...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
