Oil & Fuel air in fuel system
/ air in fuel system #1
mark vetter
elma wa.
kubota L4350 jd2240 kubota 8540
Hi gang, while baling, my M8540 began starving for fuel. Tractor has 750 hrs and is like new. Drained tank,changed fuel filter, drained water separator. made sure oring intact and tight. Tractor will idle all day but not handle a load without starving for fuel. The water separator level constantly goes from full to half,in a rhythm. I have bled to the injector pump using the hand pump on filter but have made no real headway. Any ideas?
/ air in fuel system #2
Have you blown back thru the fuel line into tank? Not by mouth but with compressed air.
that was to be my next step. I cut the old fuel filter up and inspected it. didnt seem overly plugged. My fuel supplier is now using biofuel at 10%.Not sure if that can be an issue. I have seen the screen plug before in the tank. Thanks for the reply.
/ air in fuel system #4
On the Orange forum another owner with similar issues finally got the solution.
Here is what he said:
I finally got my neighbor who is a qualified diesel tech to come help me. He pumped hand pump much longer than the other people I had helping me & engine started running so I guess it had air between hand pump & inj pump.
Thanks to all that replied,
Dave M7040
/ air in fuel system #5
Is fuel tank venting? I once owned a M4900 that acted very similar to your tractor. I found a fuel passageway clogged in water separator housing causing the fuel starvation.
/ air in fuel system #6
I think Tx Jim's suggestion is a good one. But also wondering if the fuel filter you put on was Kubota OEM or an aftermarket filter?
thanks for the tips folks. After finding out what the fuel path is from tank to inj. pump, I blew air back thru the water separator to the tank. I then bled system using the pump on fuel filter. fired it up and everything looked good,baled hay all day today without a hitch. I looked at the fuel filter guts again and a thin pasty clay feeling material seems to have coated the entire surface. From now on if i see the water separator surging like it was i will believe the lift pump is starving for suction.
/ air in fuel system #8
Mark
Thanks for update. I'm glad you got it running.
Jim
/ air in fuel system #9
Pretty common thing especially those with 90* petcocks and fittings coming out of the tank. Doesnt take much to clog that little hole up. glad ya got it going.
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2012 Ford Expedition SUV (A61574)
2012 Ford...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2005 Trail-Eze TE70HT53 54ft. 42 Ton Hydratail T/A Drop Deck Trailer (A61573)
2005 Trail-Eze...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
