air in extension hose?
   / air in extension hose? #1
RandyK
North Missouri
John Deere 4500
I made two 8ft hose extensions to go from my mid-scv's to the rear. They have quick connects on both ends. When I first use these won't they have air in them? Will this bleed out automatically or do I need to do something or is it even a problem at all? When they are connected to the mid-scv and nothing is connected to the other end, won't the relief just operate when I open the valve? Am I missing something?
   / air in extension hose? #2
Install them and start using them. The air in the line will be replaced by fluid and make it's way thru the system and back to the reservoir air vent...
   / air in extension hose? #3
Yup, As Ron said, the lines will self bleed.
   / air in extension hose? #4
Don't forget to check the fluid level in the reservoir afterwards. The fluid that fills the hoses needs to be replaced. Depending on line diameter and length that could be enough to lower the reservoir level somewhat.
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
BESTWAY AG LOT NUMBER 53 (A53084)
BESTWAY AG LOT...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
12in Backhoe Bucket (A52748)
12in Backhoe...
