Air filter light stays on
   / Air filter light stays on #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
My L3010HST has the usual Easy Checker lights on the dash. This morning the one listed as "Engine Intake/Combustion Air Filter" came on and stayed on. So I popped the hood and took a look at the air filter. The secondary element (inner) was absolutely clean, but the primary (outer) was a little oily and had been in place for nearly 100 hours. So I changed it. The evacuator valve is clear of dust or debris, and I found no evidence of rodent nesting anywhere. The cats are obviously doing a fine job in that regard. /w3tcompact/icons/smile.gif
The radiator and oil cooler screens are clear, and there's just a little pile of old leaves way down between the battery and the radiator. It all looks pretty good, right? The engine fires right up and runs good and strong. So why won't the idiot light go out?
What should I check next? /w3tcompact/icons/frown.gif
Pete
   / Air filter light stays on #2
Pete,
The air filter restriction sensor is a fancy spst switch...
Take and disconnect the plug going to it to determine if it's shorted {disconnect & the light should go out} or use an ohmmeter across it and a good sensor will read open...
Thanks, John. For an unregistered guy, you're okay! /w3tcompact/icons/wink.gif
I'll check this out tomorrow afternoon. With an ice storm coming there's not much else to do.
Pete
   / Air filter light stays on #4
Pete,
First you can't hold your fluids, now problems with your wind! /w3tcompact/icons/grin.gif
There was a post about 6-8 months ago about your exact problem. I think the problem was a stuck sensor. Can't recall if the sensor was replaced, whacked until it worked or taken apart and cleaned. It did turn out to be a simple fix, though.
John Bud
Sheesh! I went out this morning to check the sensor and the light was out. I fired up the tractor and let it warm for fifteen minutes so I could back her out into the sunlight, and when I came back to put her into gear the light was out. Go figure!
Pete
SCAN TO RECEIVE TEXT UPDATES (A52709)
SCAN TO RECEIVE...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
JOHN DEERE 300 GALLON NITROGEN APPLICATOR (A52708)
JOHN DEERE 300...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
