gsganzer
Elite Member
- Joined
- Jun 11, 2003
- Messages
- 3,044
- Location
- Denton, TX
- Tractor
- L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
I have a single stage Ingersoll air compressor in my home shop. It developed a problem that prevents it from charging to greater then 80 psig. The deadband on the switch is set at 90psi (decreasing) and 120psi (increasing). Therefore the motor tries to run continuously until the thermal overload kicks it off. Obviously the compressor should (and used to) be able to charge to >125 psi.
Anyone run into this yet. Before I pull the head off and inspect the internals, is there a quick way to tell if it's the rings, checkvalves, internal relief etc?
The compressor is only about 4 years old and really doesn't have that many hours on it. I've also changed the oil at least annually if not more frequently. I'd be surprised if it needs rings already. Any help would be appreciated.
