Dutch445
Elite Member
got the kobalt 17gallon air compressor 2 years ago. i gets used
every once in a while, pump up tires, impact gun to change tires
or do a brake job etc. sits around most of the time doing nothing.
i always liked to back down the regulator to take any pressure out
of the lines, which always leaked, and that way i always had air
in the tank for a quick tire pump.
went to use the compressor sunday nite, and as i turned that
regulator valve it came off in my hand, and has stripped the
threads from the regulator.
i would imagine the part can be purchased for $40 or so, but
is there any reason not to tap it out to a larger size thread
and use a bolt in the regulator? i might be able to find a
knob with stud on it if i look around.
looks like white metal that stripped out.
