air cleaner filter for 2015
   / air cleaner filter for 2015 #1
crackercap
I am in the process of my 50 hr service, i have bought and installed the oil, hydraulic and diesel filters, but the air filter i purchased from napa using a cross reference for wix filters(46387) is no way near the original filter. Lubner
filters shows the number(LAF8620) NAPA says this number cross references to the above WIX #. Anybody out there no of the correct part number for a napa filter for the 2015?
   / air cleaner filter for 2015 #2
I don't have a good X-ref, but why did you need to change it at 50 hours? I didn't think that was called for in the manual.
I did a lot of work under dusty conditions and it showed a lot of dust in the filter and since I was replacing the others, I decided to give it a fresh breath.
   / air cleaner filter for 2015 #4
Here's what the Fleetguard cross reference brings up. Note, it list a Kobota part number direct cross reference at the bottom.
Fleetguard part information for AF4502K is listed below.
Part: AF4502K
Manufacturer: FLEETGUARD
Part Type: Air
Cover Diameter: 124.5 mm (4.902 in)
Fin Diameter: 106 mm (4.173 in)
End 1 ID: 11.2 mm (.441 in)
End 2 ID: 45.5 mm (1.791 in)
Overall Height: 183 mm (7.205 in)
Additional Information:
KUBOTA 1585211080
Diesel Power, thanks for the reply, this looks to be the same as the NAPA filter, but unfortunately it will not fit the 2015 canister, the filter that is in the tractor now is a one piece paper filter. I sure would hate to have to pay my local dealer $82.29 but unless i can come up with another option, I will have to do that. As simple as this filter is i am sure some manufacturer out there has it at a much lower price..
   / air cleaner filter for 2015 #6
At 50 hours, I'd give it a blast of compressed air and shake it out. I've heard some recommend not using compressed air on air filters but, I've done it for some time now with no detrimental effects.
   / air cleaner filter for 2015 #7
This may seem like a dumb question but where did you get the original filter number from? Did you get it out of the owners manual or off of the filter that is in your tractor now? If you got it out of the manual it could be that they had a mid year model change, changed to a different filter housing (which uses the above pictured filter) and never changed the owners manuals to show what it really takes. Check the number on the correct filter you have now and see if it's different. Wouldn't be the first time I have seen something printed wrong.
   / air cleaner filter for 2015 #8
Have you checked out the baldwinfilters.com website - they show a cross to their PA3664-fn and they show the specs and the OE part numbers.
Baldwin is pretty good quality. We have a dealer in our area and they seem to be price competitive.
Garth
   / air cleaner filter for 2015 #9
The Baldwin PA3664-FN crosses directly with the Napa 6387 and the Fleetquard AF4502K.
Crackercap claims these Napa and Fleetquard filters #'s are incorrect. So the Baldwin # would also be incorrect..
   / air cleaner filter for 2015 #10
crackercap,
Can you give us a name and numbers off your original air filter?
New Holland 824 2 Row Corn Head (A50774)
New Holland 824 2...
1993 Ford F700 Stakebody Truck (A51692)
1993 Ford F700...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
