Air bubbles arround injectors
   / Air bubbles arround injectors #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I ran my 1900 out of fuel today and when I was bleeding the injectors the fuel was running down arround the base where they screw into the head and I noticed air bubbles. I checked to make shure they were tight and they were. Is there a some type of seal there or is it a machined fit. It isn't leaking bad but it shouldn't leak at all. My service manual wasn't a lot of help.
Bill
I should make it clear that it is leaking compression arround the base of the injectors
   / Air bubbles arround injectors #3
if I remember right my old MF165 had a seal there.
   / Air bubbles arround injectors #4
Probably some type of brass washer under the injector.
2005 TerraGator 8104 (A53472)
2005 TerraGator...
New Long Forks (A53002)
New Long Forks...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
JOHN DEERE 17P LOT NUMBER 227 (A53084)
JOHN DEERE 17P LOT...
John Deere 2155 Tractor (A51573)
John Deere 2155...
