Air bubbles arround injectors
   / Air bubbles arround injectors #1
Hooked_on_HP
Veteran Member
Coal City IL
Ford 1900 FWD Kubota F2100E
I ran my 1900 out of fuel today and when I was bleeding the injectors the fuel was running down arround the base where they screw into the head and I noticed air bubbles. I checked to make shure they were tight and they were. Is there a some type of seal there or is it a machined fit. It isn't leaking bad but it shouldn't leak at all. My service manual wasn't a lot of help.
Bill
I should make it clear that it is leaking compression arround the base of the injectors
   / Air bubbles arround injectors #3
if I remember right my old MF165 had a seal there.
   / Air bubbles arround injectors #4
Probably some type of brass washer under the injector.
NEW Fork Extensions (A53002)
NEW Fork...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2024 JOHN DEERE 4044M LOT NUMBER 65 (A53084)
2024 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
