Air Bound
   / Air Bound #1
Anonymous Poster
Epic Contributor
YM1500. Changed fuel filter. filled bowl and filter.(overflowing as I tightened it)cranked. almost started. now it wont start.
Air Bound?
Where to bleed from and what's the procedure?
   / Air Bound #2
There is a hex nut (about 12 mm) with a phillips drive, above the filter a few inches, as I remember. When I changed the filter in mine, I loosened that nut until fuel ran out. Then I tightened it and was able to start the tractor with no problem.
reb
   / Air Bound #3
Correction: It is a hex bolt head, not a nut. This #@?! computer isn't smart enough to print what I mean. /forums/images/graemlins/blush.gif
reb
   / Air Bound #5
There is a thread here somewhere that has really good instructions on bleeding the fuel system. Have you tried searching the forum? Do you have the manuals? It is in there too.It isn't too hard but the EPA would probably have a heart attack if they ever saw us doing it.
Chris /forums/images/graemlins/shocked.gif
Huskee 20 Ton Wood Splitter (A51573)
Huskee 20 Ton Wood...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
12ft Freedom Chip Body (A51573)
12ft Freedom Chip...
FAKE (A52472)
FAKE (A52472)
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
