Air Blow Guns
/ Air Blow Guns #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I wasn't really sure where to put this.
Just lost another pistol style air gun. First it didn't always shut off, then it just blew up. Now I'm in the market.
As far as cleaning off mowers and such goes, I have recently started using a four stroke Makita leaf blower, which I find more effective.
So, what's out there? Is there a difference between venturi type guns and non? Do all the longer nozzle, pistol type blowers always break? I had a bunch, now I have none. Just a short rubber tipped type gun for blowing into a port.
/ Air Blow Guns #3
Off topic I guess...and I don't have a quick picture. Saw your air blow gun title...reminded me of something.
Back in 1982, I went to Peru (S. America) with my father. Went to Maccu Piccu, Iquitos, Lima, Nazca lines...
Well, one of the trinkets I bought was a blow gun. Complete with darts (still have it to this day)
Yeah, this was more of a trinket blow gun however, it WILL work.
So, time to go home, this thing is fragile and I don't want to have it smashed in the luggage....so I literally put it around my neck and head to the plane.
Got to security and walked on through. I don't think it was on the Peru side but probably changing planes in Atlanta. Security guard stopped me and asked what it was.
"It's a blow gun..... it blows these darts" as I freely showed him one of the darts.
He looked at it....paused.... looked at me....looked back at it....back at me.
He clearly did not know what to make of this situation. Though it was a trinket type thing (it's about 15 inches long and the darts are maybe six/seven inches long)
He finally just handed it back to me and said go ahead (board plane).... and off I was to go home.
I'm speculating that I'd probably not have that same experience and ending if I were to try the same thing today.
/ Air Blow Guns #4
This was a blow gun that I got while in the Amazon jungle near Iquitos.
/ Air Blow Guns
I had to think of those blow guns too when posting this. My best friend in grade school had just come from living in Lima Peru, and told me of blow guns with "Kirachi" sp? or some such poison.
/ Air Blow Guns #6
curari ?
Also spelled curare...
/ Air Blow Guns
Thanks. That's the stuff. Kirachi is in Pakistan, no?
/ Air Blow Guns
I have a four foot Milton style blow gun that use for cleaning out the 2x4s in the shop. Stepped on, broke and rethreaded it a few times already.
The 10 or so inch blow guns, tend to try and take out your eye when whipping back into a spring loaded reel!
/ Air Blow Guns #9
Most of my tractor blowing is done using a Milton 2' wand. They last forever for me.
Milton Extension Blo - Gun
I use a Harbor Freight version of that one which I have had for about 15 + years.
Mowers and most things now days I just use a Stihl gas blower. More volume works quicker.
TBS
/ Air Blow Guns
And blows stuff clear of the machine better. Plus, you don't need to pull the air hose a good distance out onto a grassy area, clean it, and put it back.
/ Air Blow Guns #11
The Typhoon Pro guns do a great job and are well made if you have the volume. I have a 12?" and a 6"
/ Air Blow Guns
Are they a venturi style? Never owned one like that.
Boy, looked at them. The last time I saw instuments like that, I was strapped to an alien examination table! lol
/ Air Blow Guns #13
WoW!!! If they made a 16 oz. portable compressed air cylinder and a holster....... Strap that Multi-Jet unit right to my hip!! Their design engineers are taking clues from Star Trek and similar SiFi flicks. And the cost is............??
/ Air Blow Guns #14
I have blow guns just about everywhere I need to use one but the one that gets the most use is one I made.
I took an air compressor quick-connect male plug and a female plug, and screwed them together.
I get a lot more air out of it than any blowgun I have ever used.
My compressor makes about 15 psi, but it can't quite keep up. But with that high volume, the mess is cleaned up much faster.
I call it my pneumatic broom.
/ Air Blow Guns #15
I've got several of the old style cast metal ones. Since they have threaded ends I put in some AN fittings and have one that has a 3' section of brake line with a bend at the tip for floor and behind stuff cleaning, one with a 8" straight tube for general use, one with a 90 degree fitting for radiators and such, and a rubber tipped one for things like emptying out a pressure washer hose where you need a positive seal.
/ Air Blow Guns #16
Sooo...... I picked up a Typhoon blow gun from House of Hose in Spokane this morning. It is MANY magnitudes superior to my home made one. Pull the trigger - it actually has recoil. Now I have to find one of my disposable dust masks and I can blow all the sawdust & crap out of my work shed.
I got the model with the 12" extension. I ran my compressor at 100 psi. $24.95
/ Air Blow Guns #17
That sounds like a good deal to me. I'm sure I had the privilege of paying more. Though I have to say, "The House of Hose" seems like a place my ex sister in law might of worked...
/ Air Blow Guns
You must be confusing that with "House Of Hose Bag". Common Mistake.
/ Air Blow Guns #19
You must be confusing that with "House Of House of Hose Bag". Common Mistake.
Probably not owned by the same guy? :laughing:
BTW, if you guys need GREAT flex hoses, go with the Coilhose Pneumatic too.
CAT 963D 4-in-1 Bucket (A68134)
CAT 963D 4-in-1...
2021 TAKEUCHI TB240 EXCAVATOR (A65056)
2021 TAKEUCHI...
2022 WESTERNSTAR 4700 CONCRETE MIXER (A67714)
2022 WESTERNSTAR...
2012 DRAGON 130BBL VAC TRAILER (A67714)
2012 DRAGON 130BBL...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
JOHN DEERE 5090 EL TRACTOR (A65057)
JOHN DEERE 5090 EL...
