Tiller agric tiller
   / agric tiller #2
bkennedy said:
Does anyone have experience with small Agric brand tillers (45")?
I purchased my agric tiller (AFMJ55) with slip clutch used a few years back and I till about 5 acres per year with it every spring and fall. It is a chain drive model. I have very rocky land and I have had no problems with is so far.
Steve
   / agric tiller #3
I have an Agric 5' model (not sure which one, it's outside, I'm inside)
But it's been pretty unstoppable (after I fixed the driveshaft, it was too long)
I've probably done 40 to 50 acres with it over the past few years.
Does a real nice job, I've had no problems with it or parts wearing out, etc
   / agric tiller #4
I have an Agric AL-50 that I use for planting about 6 acres of food plots. It was VERY used when I got it 2 years ago. I replaced the chain and a few tines. It does a good job of tilling when I can keep the gearbox support bolts from shearing. I have drilled and tapped the original 10 mm bolt holes on the gearbox for 7/16" bolts (grade 8) and they broke also. I just recently drilled and tapped for 1/2" bolts. Haven't used it with the larger bolts yet. If they shear I will add more support to the drive shaft axle from the gear box to the chain sprocket with U-bolts or something similar. I will also try tilling at the shallowest depth at first and gradually increase the depth on additional passes. If you need parts try dnequipment.com.
Hose Reel (A55758)
Hose Reel (A55758)
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
Towable spreader (A55973)
Towable spreader...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
