Tiller Agric Tiller Gear Oil SAE 90 or SAE 140
   / Agric Tiller Gear Oil SAE 90 or SAE 140 #1
Luremaker
Veteran Member
Ontario
Kubota L3130HST & NH TC18
I managed to get a copy of the owners manual for my used agric tiller. Now this manual is in English and Spanish. The English page says to change gear oil and use SAE 90 every 150 hours. The Spanish page says to use "El aceita deberia rebosar SAE 140 hasta el nivel situado" every 150 hours. Does anyone know if North American SAE 90 gear oil the same as SAE 140 European?
   / Agric Tiller Gear Oil SAE 90 or SAE 140 #2
90 or 140 will work. I have an Agric also and I have a little of both in it.
   / Agric Tiller Gear Oil SAE 90 or SAE 140 #3
If you use 140, don't try tilling in January ;-)
I have 140 in mine as it is used in tough soils.
jb
   / Agric Tiller Gear Oil SAE 90 or SAE 140 #4
SAE is standardized so the answer is no, SAE 90 and SAE 140 are not the same. In your area, that being Canada, I would probably go with the SAE 90 weight oil. I suspect you see more colder weather than hot. Higher viscosity oils also tend to run hotter as the thicker oil increases resistance to flow. Pick a good high quality SAE 90 and your tiller should be happy for many years to come.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
ECHO PB-5810 H/T GAS BACKPACK BLOWER (A51248)
ECHO PB-5810 H/T...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
