AGCO GT45:: the cab's A/C drain is plugged
   / AGCO GT45:: the cab's A/C drain is plugged #1
sheakev
Wisconsin
AGCO GT-45
Just got this tractor only 140 hours on it). Last weekend very humid had the AC running and was hooking up a new brush hog to it. I turned the A/C on high and water started spitting out of the vents.
I moved the tractor and water POURED out of the vents.:confused:
I checked around and it was not at all obvious where the water was to drain out. Nothing in the manual.
Any thoughts would be great. I will try to find a local dealer but I think they are two counties away from me.
Thanks
   / AGCO GT45:: the cab's A/C drain is plugged #2
The only place the A/C drains can logically be run is down through the cab pillars. Look at the bottom front of the cab at the bottom of the 'A' pillars. If not there, check under the fenders at the bottom of the 'B' pillars if your cab has 'B' pillars. Then check the rear cab corners.
   / AGCO GT45:: the cab's A/C drain is plugged #3
If I remember correctly they are in the front A-pillers on the cab. Seems like that is where it drains from mine. But I would half to look to be sure.
2015 GMC 3500 HD 4x4 Crew Cab Pickup truck (A55973)
2015 GMC 3500 HD...
Butterfly Artwork (A55758)
Butterfly Artwork...
2022 Schulte 2500 Giant Rock Picker (A55315)
2022 Schulte 2500...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 KENWORTH T8 SERIES (A58214)
2019 KENWORTH T8...
