AGCO GT45:: the cab's A/C drain is plugged
   / AGCO GT45:: the cab's A/C drain is plugged #1
sheakev
Wisconsin
AGCO GT-45
Just got this tractor only 140 hours on it). Last weekend very humid had the AC running and was hooking up a new brush hog to it. I turned the A/C on high and water started spitting out of the vents.
I moved the tractor and water POURED out of the vents.:confused:
I checked around and it was not at all obvious where the water was to drain out. Nothing in the manual.
Any thoughts would be great. I will try to find a local dealer but I think they are two counties away from me.
   / AGCO GT45:: the cab's A/C drain is plugged #2
The only place the A/C drains can logically be run is down through the cab pillars. Look at the bottom front of the cab at the bottom of the 'A' pillars. If not there, check under the fenders at the bottom of the 'B' pillars if your cab has 'B' pillars. Then check the rear cab corners.
   / AGCO GT45:: the cab's A/C drain is plugged #3
If I remember correctly they are in the front A-pillers on the cab. Seems like that is where it drains from mine. But I would half to look to be sure.
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2015 Freightliner Squirt Bucket Truck (A55973)
2015 Freightliner...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
