Again - what grease - but with a few qualifiers
   / Again - what grease - but with a few qualifiers #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
As he wrote:
Also what grease are you guys using? I have a tube of lucas red and tacky, and a green tube of lucas. At work we use the green lucas grease, and also sta- lube red plex I believe it is.
I'm just entering the world of LOT'S of zerks to fill.
Qualifiers over most of the grease threads:
I'm wanting to use a multi-purpose grease for most of the fittings (tractors, truck, Backhoe, etc.). Things that SPECIFY a certain grease I'll use different.
I'm wanting BULK, gallon or 5 gallon, not tubes, 2 tubes cost about $10 & 5lbs less than $20.
So - what's a good grease in a 1 gallon or 5 gallon container?
   / Again - what grease - but with a few qualifiers #2
SCHAEFFER GREASE.goggle it.
   / Again - what grease - but with a few qualifiers #3
I buy molly grease from TSC. Molly is an excellent, cheap, additive that makes plain grease qualify as "heavy duty".
It is more important to grease on schedule than to buy a hyped super-grease with heaps of testimonials.
That's my theory - I just bought 10 grease guns so I could make sure I didn't here the excuse "Well I couldn't find a grease gun"
   / Again - what grease - but with a few qualifiers #6
   / Again - what grease - but with a few qualifiers #7
One of the best on the planet, most water resistant and water insoluble . Get it on your hands and even soap and water will not remove it easily. provides excellent anti-seize protection under high loads. Outstanding adhesion enables this product to stay in place better than most other greases.
https://www.mystiklubes.com/do/product/665005002
   / Again - what grease - but with a few qualifiers #8
Overgreasing with average quality grease will do a lot better than undergreasing wit the best grease.
   / Again - what grease - but with a few qualifiers #9
Before you mess with tubs of grease (messy) check out the tubes of moly that HF sells. I use that with good results. Tubs work best when you have a air driven loader pump to fill your gun. Oh, don't buy there pneumatic gun, it sucks, went through one a year, finally bought an Alemite.
Ron
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2020 KENWORTH T680...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
