AGAIN 16X16 FORD NH TRANSMISSION
   / AGAIN 16X16 FORD NH TRANSMISSION #11
Hello from a new member. I'm not sure if I'm in the right place on the website to ask a question, but I'm sorry I'm new to this. I have a 1985 ford555b. After I put it in 1st gear, I then shift into forward or reverse on the column. I do have all the forward gears but not reverse. Could this be the dump valve assembly or something else. Can anyone help??? Thank you, Pete
   / AGAIN 16X16 FORD NH TRANSMISSION #12
Julesb,
From your description I think prob lies wit clutch cable/dump valve adjustment which has the result of causing a conflict between clutch potentiometer and pressure switches and pwm solenoid and tcm thus no drive, tractor moves couple of feet drive lost or cp on dash. To adjust cable remove return spring on dump valve lever( on trans side cover inside accumulator) then loosen lock nuts on clutch cable and with 31.5mm spacer against bulkhead depress clutch pedal to touch spacer. Then pull outer casing of cable down until inner cable is taut, with cable still held taut thread lower nut up against bracket to hold tension. Lock cable in this position using upper nut. Reattach return spring to lever and all is hopefully ok!!!!! Other possible causes are dump valve retaining bracket cracked on inside of trans control valve similar symptoms to cable adjustment ( seen on tractor last week after trans had 23000hrs on clock) or problem with 5volt line reference from tcm(pwm solenoid amps incorrect voltage ok) v common on tractors with electro link
Kevc
I'm having this trouble with 92 7740.It's kicking a e22 code and won't move. Can you explain in more detail about the problem with the five volt line reference from the tcm(pwm solenoid amps incorrect voltage ok) it sounds like what my tractor is doing. Do you replace pwm solenoid?
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 232,391mi Plate: Body Type: (A55852)
Year: 2002 Make...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
