Traction ag vs industrial XR 4046
   / ag vs industrial XR 4046 #1
EKUgrad
Sorry, I know that this has been beaten to death in other threads but I wanted some of y'all's opinions, too. We are looking at getting a XR 4046 and have only had tractors with R1's, dealer is pushing R4's. The tractor will mostly be used for bushhogging and some of the terrain is hilly. There will also be some general farm maintenance type work, too. Any thoughts? I was looking at the photo thread and was moderately surprised with what was able to be done with the R4's. Anyone have any idea which have a higher ply rating or weight rating? Thanks in advance.
   / ag vs industrial XR 4046 #2
I am one of the only 4046 owners I've seen on here that opted for R1's, and I had to wait longer for them because most all are sold with R4's. I believe the R4's have higher ply and weight ratings, but have not checked to make sure. I wanted R1's for the occasion that I would be in mud. What actual usage has shown me is that those occasions are very rare, and I would have been served just as well if not better with R4's. In our situation, we live on an old dairy farm that has a large concrete area that used to be a feed lot. Most of my miles/hours come on this concrete, and I think R4's would hold up to it better than the R1's. For steep, sometimes slick hills, I would still go with an R1.
   / ag vs industrial XR 4046 #3
I have a r4041h with r4 tires and pull a 2 bottom plow, use my back blade to cut ditches, brush hog 20 acres, rototill, snow removal with plow and back blade, and earth moving with a box blade! My land is flat but unless your doing ground engaging work while going up steep hills 4wd will get you where you need to go! There are situations where I wish I had more traction but for me those are few and far between and not having r1's tearing up my property is more important to me! Hope this helps!
   / ag vs industrial XR 4046 #4
dis like R4's, they are like dullies on a pickup truck. there fat, slick, and you get stuck in mud, ice, snow and on hills.
prefer R1's they will sink further down in mud and keep you going. and i can bite my way (tread) through snow. vs seating on top of the snow spinning wheels.
you can get any tire in different type of ply rating. higher ply rating = normally thicker rubber and/or harder rubber.
if it is to wet out. R1's or R4's are going to tear up the lawn, and make ruts no matter what.
   / ag vs industrial XR 4046 #5
R4's are exactly what they are, industrial. Excellent traction on concrete, hard packed ground and thin mud with hard bottom. They are wider for hard surface use. You will get stuck in mud, otherwise are ok on a utility tractor. The R4's do not clean out well and have shallow tread compared to R1. I would only get R4's if I was using the tractor on construction sites or if it was dedicated to mowing the front yard.
R1's are also exactly what they are, ag. Excellent traction on dirt, grass, mud. Not so much on concrete. This would be my choice pick for a utility tractor that will used for general farm duties. They belong on a utility tractor of this size. Had I gone with the XU5065CPS, I would have opted for R1 over the R4.
My $0.02
CT
   / ag vs industrial XR 4046 #6
Real pleased with the R4s on my XU. I also have the LS backhoe, and appreciate the wider tire profile for stability when using it and the front loader. They don't tear up the yard too badly, and handle the occasional 3 mile trip over blacktop to the in-law's better than R1s likely would. Have done bush hogging and finish mowing in sloping terrain with no need for 4WD. Insofar as ice and snow, well, it stayed like this until all the white stuff melted... I usually avoid slick and muddy situations unless absolutely necessary, and that may be why R4s work just fine for me.
   / ag vs industrial XR 4046 #7
I didn't think Roll Tide country ever saw white stuff!
   / ag vs industrial XR 4046 #8
So far I have been stuck more with R1 tires that I have with R4 tires. I think it's because the wider stance prevents me from sinking in the first place on the first pass. Thats usually enough to let me know not to try going through the wet areas a second time. But it seems that by the time your tire is sunk in the mud it's often too late anyways no matter what type tire you have. This is my first go around with the R4 tires. All my other tractors have been agg. And always thought that was the way to go and was really on the fence about it when I purchased this one. But I'll tell you 200 hours so far and I have no regrets. I like the wider more stable stance and the thicker ply that they offer. I have found traction much improved with the R4 for my uses.
   / ag vs industrial XR 4046 #9
I have a 40 horse Kubota with R4's and there have been a couple of times when I couldn't get up a slick hill that I think I could've with normal ag tires. If you're not using it on pavement or a lawn situation I see no reason to go with R4.
Thanks for the feedback, gents. You've basically all confirmed what I thought.
18' X 20' STORAGE GARAGE TYPE CARPORT BUILDING (A52708)
18' X 20' STORAGE...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2006 Dodge Ram Pickup Pickup Truck, VIN # 3D7KS28C66G203434 (A57453)
2006 Dodge Ram...
1026A (A58374)
1026A (A58374)
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
