Ag tires vs R4
   / Ag tires vs R4 #1
mayer2323
Are loaded R4 tires just as good as ag tires? Looking at new tractor with r4 tires dealer says just as good if not better . Tractor is 4wheel drive.
   / Ag tires vs R4 #2
In mud, the R1 will have much better traction than an R4. I would guess 30-50% better traction. R1 tends to ride a little smoother because the side walls are not as stiff. R4 will last longer and in most cases an overall more rugged tire.
   / Ag tires vs R4 #3
I agree R1's definitely pull better, but are harder on turf. And r1's look terrible on cut's because they are so narrow. But I agree 30-50 percent better traction.
   / Ag tires vs R4 #4
The older 4WD Kubota I sold when I got my new JD had ag tires, and they were fine except for the turf damage. No matter where I went on my place you could see the tracks for days afterward, especially if the ground was the least bit damp. I have R4's on the JD and they are great so far, sort of "trackless". I hardly ever use a ground-engaging implement (in fact, the only one I own is a middle buster), don't have any major hills, don't clear snow except maybe once a winter, and never do tractor work in the mud, so the difference in traction, whatever it is, doesn't much matter to me. Unless you plow the south 40 or something pretty often I'd stick with R4's.
   / Ag tires vs R4 #5
In mud ags are better,but,,if you have loaded r4's and 4wd,you won;t probably get stuck,unless its serious mud,believe on ice,r4's would be better than r1's,,and can tell you after last winter,loaded r4's and 4wd,work very good in 2 ft snow.
R4'S give you a more stable platform on sideling slopes,and don't track near as bad in places you don't want tracked.
   / Ag tires vs R4 #6
"Better" will depend upon the type of duties and your location.
I have used R4's and R1's. If my duties were commercial urban (paved and/or construction style dirtwork) then R4's.
Where I live, paved roads are rare except for main highways, and we measure snow in feet per day, with ice in January cured at -10f to -40f and 100+f in July. Most of my duties are ag in summer and winter, with 2 miles of driveway to keep clear in the winter as well. I tried R4's and after about a week of poor traction went to R1's and never looked back.
The R1's do have a weaker sidewall. This year I upgraded to the Michelin XM27 Michelin AG - Products - XM27 Utility & Industrial
for the fronts. It is called an R1w and it has r1 tread but industrial (R4) sidewalls.
Hope this helps
   / Ag tires vs R4 #7
The R1w makes a great tire for FEL work. R4's would compare to a "all terrain truck tire". R1 would be like a snow tire or mudder on a truck. That is why they make different styles. You just have to ask how you are going to use the tractor. The truth is you'll have them a awful long time.
   / Ag tires vs R4 #8
My tractor came with R-1's. No better traction, especially since they're loaded w/rimgaurd. But, have to be careful where i go on lawn. Usually avoid the lawn altogether. But when i do, i approach it at a straight line, will tear up, especially when turning. If I could switch w someone, i would go to R-4's. Unless you are in a high traction enviroment(row cropping, plowing sod ground, etc), R-4's are(IMO) the best choice.
   / Ag tires vs R4 #9
Short answer is NO. They aren't as good as far as traction is concerned in most conditions. And R4's arent nearly as good at tearing up sod and digging holes:D
For the most part, you have gotten some good advise here. You have to consider what kind of conditions you will be operating in.
Out in the field, ground engaging work, muddy conditions, etc. R1's will excell.
Pavement, Very hard packed soil, construction type environment, etc the R4's will not give any better traction, but they will last much much longer.
   / Ag tires vs R4 #10
Nothing beats R1's for traction period. R4's have a place but not on any of my tractors. I tried to use my uncles tractor with R4's for pushing snow and logging and it was pathetic compared to my R1's and 5 HP less.
Remember, the root word of tractor is traction.
Chris
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
WOODS RC60.20 LOT NUMBER 88 (A53084)
WOODS RC60.20 LOT...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
