AG bar vs AG Rib?
   / AG bar vs AG Rib? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
AG bar (R1) vs AG Rib (F2)
Now, I have discovered that there exist two different types of AG (R1 and F2) tires. Bar versus Rib. Every time I think it gets easier, something new comes up like this and I realize I have to come back to TBN and ask another question!!! /forums/images/graemlins/smile.gif In the NH numbering system, rib is 810860406, bar is 833860406. The literature I read says that the R1 is not recommended for loader working the two wheel drive package, yet does not make the same statement for the 4 WD package.
Question: What is the difference between AG bar and AG rib??????????? Why 2WD restrictions for loader work with R1 (bar), okay with rib (F2) vs apparently no restriction for 4WD tractor with bar (R1), or rib (F2)?
Bob
   / AG bar vs AG Rib? #2
A rib is usually referring to a circumferential raised section on the tire, usually 1 to 3 for tractors. They are meant for the front wheels of 2 wheel drive tractors, originally intended to make it easier for the tractor to climb out of furrows and such.
Load carrying capacity will be a function of size and ply rating. With a 4wd tractor, you probably want 6 ply R1s. The F designation may be an artifact from the original Front wheel placement, the R from rear.
   / AG bar vs AG Rib? #3
Did a little digging at firestoneag.com...
Yes, F2 "rib" is a designator for a front tire on 2WD tractors. Here's an image:
The URL for this tire is Champion Guide Grip 3-Rib F-2
I have a similar three rib front tire on my JD 1020 2WD tractor. As you can probably see from the image, these tires are primarily designed for steering control.
   / AG bar vs AG Rib?
</font><font color="blue" class="small">( Did a little digging at firestoneag.com...
I have a similar three rib front tire on my JD 1020 2WD tractor. As you can probably see from the image, these tires are primarily designed for steering control. )</font>
Thanks for the explanation. Makes prefect sense.
Bob
   / AG bar vs AG Rib?
</font><font color="blue" class="small">( A rib is usually referring to a circumferential raised section on the tire, usually 1 to 3 for tractors. They are meant for the front wheels of 2 wheel drive tractors, originally intended to make it easier for the tractor to climb out of furrows and such.
Load carrying capacity will be a function of size and ply rating. With a 4wd tractor, you probably want 6 ply R1s. The F designation may be an artifact from the original Front wheel placement, the R from rear. )</font>
Thanks, now I understand F2.
Bob
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2023 WESSEX RMX500 LOT IDENTIFIER 44 (A53084)
2023 WESSEX RMX500...
CHALLENGER MT525B TRACTOR (A51247)
CHALLENGER MT525B...
