aftermarket starter and solenoid for Lx 172, Kawasaki 14hp
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #1
hslogger
Platinum Member
western oregon
currently l4400 stick
I need a new starter assembly for my old mower. Bendix spring is shot, ditto solenoid.
Anyone have suggestions and good review for aftermarket or rebuilds?
thanks
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #2
It seems unusual that you would have two failures at the same time. What happens when you connect the battery positive terminal to the stud coming out of the starter, not the solenoid?
starter spins, gear doesn't rise up to engage.
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #4
OK now we are getting somewhere.
Try this next, jumper the battery positive to the large terminal on the starter solenoid, then use a smaller wire to connect the small terminal on the solenoid to the positive wire connected to the large terminal of the solenoid.
Lets see what happens.
Richard
I got no action what so ever
Richard
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #6
So based on your investigation, I would say that you indeed need a new solenoid. Now I don't know the price of just the solenoid vs the price of a totally new starter difference is. Look around and see what is available and the cost.
Good luck,
Richard
   / aftermarket starter and solenoid for Lx 172, Kawasaki 14hp #7
Richard could be right on here. If you Google the Denso number on the solenoid, it is quite easy to get them much more affordably than from Deere.
I bought a new solenoid on Ebay and it came, I installed it and it didn't work worth a hoot, and the install mechanism, ie a nylon finger was difficult. I pitched it and bought a new starter with solenoid from Jacks Small engines. installed it and starts like it should. I have had good luck with Jacks and E replacements over the years and reckon I should have done that to begin with. I will save my old starter and if the day comes I can find someone to go through it I might. Thanks for your inputs.
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2022 Chevrolet...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
UNIVERSAL WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A51248)
UNIVERSAL...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
