AFtermarket seat
   / AFtermarket seat #1
L Seven
Kioti DK45
Howdy all.
Does anybody know where I can get a decent / cheap aftermarket seat for a DK45? I'm looking for a drop in replacement that does not need modified.
Thanks
   / AFtermarket seat
Not sure of your definition of cheap or modification is, but Northern Tool has replacement seats. Just do a search on tractor seats.
Portable Generators, Welders, Pressure Washers, Power Tools | Northern Tool + Equipment
Hi Sandlot,
Thanks for the reply.
I am looking for something in the $100 +/- range. I have looked at Northern Tool and Tractor Supply but none show the mount.
I wanted to be able to take the old seat out and put the new seat in without having to do any mods to the new seat or the current mounting configuration.
I was hoping that someone else might have replaced their seat and could point me to a part # on N. Tool or somewhere else.
Thanks
   / AFtermarket seat #4
I am about to find out as my DK 35 seat has split open and the mounting hardware (bottom of seat metal plate and the two bolts holding it to hinge) are rusted off and I need to install a new seat. TSC, here I come.
   / AFtermarket seat #5
Hi Sandlot,
Thanks
Well, I have "installed" my new tractor seat from TSC. Despite the term "universal" fit, it is not. The new bottom plate at front can be drilled to use threaded acnchor bolt holes on tractor body beneath the seat (pan ?) but not the rear ones as the universal plate is much too narrow for the rear anchor bolts in the pan. I will need to reconfigure the old seat's bolt down plate to align with new seat bottom plate. Annoying but.....
Best of luck with your problem.
   / AFtermarket seat
Thanks Avondale.
I bought a "close" match from Tractor Supply (just happened to be going by the other day). Now I have to get the rusted bolts out of the old seat and make a bracket that will fit the new seat. I guess I should have just called a Kioti dealer and ordered a new seat! :confused2:
Thanks for the replies.
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
2005 KUBOTA L39 BACKHOE (A51246)
2005 KUBOTA L39...
WESSEX 1.5T LOT NUMBER 172 (A53084)
WESSEX 1.5T LOT...
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
