ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 13,542
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
What saw model you have with this micro 1/4"? Only the very small gas saws and battery saws I know of use it.
I know on the 150 you would NOT want to move up to 3/8LP like mentioned above. It uses MICRO 1/4" for a reason.
Don't even know how it would handle full size 1/4". Might check to see if that would work or not.
The Stihl has buckets of power and a larger CC engine than our Echo's have and they use larger pitch chains. (a down side is it weights more) We knew that the Kombi has more HP and hope to run the .180 string heads which takes serious power to spin. Sawing wood takes less HP than spinning these large string.
