Aftermarket Oil Filter for L4701
   / Aftermarket Oil Filter for L4701 #1
Desertfireguy
Avery
Kubota L4701
Doing my first 50hr service soon, but can't seem to find ANY information on which oil filter to use. Manual says use Genuine Kubota Parts, gee thanks. There's not even a number on the filter, just grey casing. Any help would be appreciated. Would also like opinion on filter brand to use if you've found a match that's not Kubota OEM.
   / Aftermarket Oil Filter for L4701 #2
Check your owners manual. The part number to get you started is probably there. Once you have one part number you can do cross reference searches that will give you the part numbers for tons of other brands that will work.
If not listed somewhere in the manual...... and if a search on the specific engine won't provide a starting point you may have to buy "1" at the dealer to get the number.
Messick's lists a # HH164-32430 for the L4701. Doing a Google on the part number will give you Fram, Purolater, Wix, Luber-finer & many more.
Kubota L4701 | Messick's
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
John Deere 3PT PTO Post Hole Digger (A55218)
John Deere 3PT PTO...
12ft T/A Park Dump Trailer (A52377)
12ft T/A Park Dump...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
ASCO Transfer Switch (A52377)
ASCO Transfer...
