Aftermarket clutch disc for JD 870
   / Aftermarket clutch disc for JD 870 #1
Jim1934
Clarkston , Mi
JD 870
Greetings,
I need to replace the traction clutch disc on my JD 870 tractor.
Can someone who has used an aftermarket clutch disc comment on its quality
and perhaps recommend a source?
Thanks, Jim
   / Aftermarket clutch disc for JD 870 #2
What is the part no. of the disc you are looking for?
:welcome: to TBN
I don't know. will have to buy parts manual.
Would prefer to buy genuine JD pressure/spring plates(2) and a traction disc.
It is a dual clutch.
   / Aftermarket clutch disc for JD 870 #4
Look the parts up in jdparts.com (free registration) and just enter your model no. (870) and go to 870 compact utility and Clutch under the alphanumeric listing.
Here is a pic of the schematic. It shows the PTO clutch plate and the main clutch disk.
Main is part no. M808625 (item 6)with a reference to the same being LVU801100. You can do a net search on those numbers.
PTO is M804454 (item 1)
That link brought me a popup saying I had a virus and should call 1-866-346-8267
to get it repaired. That no. is spam.
Can you please give me the part number for the two pressure/spring plates?
Item no. 3 in the diagram.
Thanks, Jim.
   / Aftermarket clutch disc for JD 870 #6
Yes
3 CH13687 Disk Spring 2 DIAPHRAGM
But jdparts.com should not be showing with a virus, unless you have it on your computer (as indicated by the number to call).
2018 HAMM H7 SMOOTH DRUM ROLLER (A51246)
2018 HAMM H7...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
