After you clean around zerks
   / After you clean around zerks #1
Jw5875
NW Pa.
Kubota L3400
Several tools available for clearing the grease channel.
I just purchased a "Grease Buster" tool made in Ohio.
JW5875
   / After you clean around zerks #5
I've never had a plugged grease fitting in 30 plus years because I don't use cheap clay based grease. I only use synthetic grease that don't coagulate in the fitting.
   / After you clean around zerks #6
I just use an old rag to wipe the zerks clean and never had
any problems of any kind doing this.
I also like the synthetic grease Synthetic wheel bearing grease is great for any bearings
willy
   / After you clean around zerks #7
The noodle coming out of that part with the guy using the tool is very indicative of what cheap clay based grease looks like. High quality synthetic grease never does that noodle thing.
   / After you clean around zerks #8
I just wipe the top of the zerk with my finger or a rag. Never in 40 years had anything like that kind of problem.
   / After you clean around zerks #9
Me neither. Only time I've had trouble greasing (pistol grip grease gun) is when there is a load on the item being greased.....such as the FEL etc. Always wanted a fancy battery operated gun or that lock on gizmo tip.....just never bought one. Too late now at my age.
BTW, I never cared for synthetic grease because it is so hard to clean up afterwards. Been using Valvoline multipurpose for years....on everything.
Cheers,
Mike
   / After you clean around zerks #10
I never knew the coagulation was a side affect of using clay based grease. Coagulation is a big problem - think PTO shafts (for which I've been using DryLube, not knowing why the grease hardened up). Thanks for input.
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
Scag Mower (A50324)
Scag Mower (A50324)
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A52748)
2018 Rock Solid...
