After the ball do you lube leaf springs?
   / After the ball do you lube leaf springs? #1
schiker
Anderson, SC (Northwest part of SC)
Ford 3000, 1972 LCG, JD 5603
I replied to thread about greasing my hitch. I do grease the ball.
Since my trailer sits for long periods w/o use I also like to spray some PB Blaster, WD-40, Marvel Mystery Oil, Chain Lube etc, what ever is nearest at hand, on the leaf springs, shackles, and pivot. Seems to quiet the trailer down so you don't hear quite so many creaks and squeaks. There are no pads between my leafs and they are generally not real dirty. If it was real gritty and dirty I would spray it off before lubing.
What else little things do you do each time you hook up?
   / After the ball do you lube leaf springs? #2
The one caveat I would like to share is that WD-40 is NOT a lubricant. Please note that nowhere on the cans bottles and literature does it say lubricate. Although there is an amount of "slipperiness", this is a rapidly evaporating carrier. The primary function of WD-40 is a solvent and rust dissolver. It "lubricates" by breaking stuck bonds, not by making something less "frictionable" for any length of time. Silicone, Teflon and Lithium are better, more longer lasting choices for true lubrication.
For example, Holmes Halley garage door machines call for monthly lubrication and specifically advise against WD-40 and recommend white lithium grease. An initial spray of WD-40 may help dissolve old layers of grease and dirt build up, but needs to followed up by an application of an actual lubricant for best results.
   / After the ball do you lube leaf springs? #4
Beat me to it:p It is a lubricant although not a great one...I use the stuff by the gallon in pump sprayers...BTW not sure about the health effects of it but it makes a great hand cleaner when grimy/greasy and it doesn't dry your skin:cool:
WD-40 is not my favorite by any means. It tends to gum up precision stuff but its better than nothing (for bare metal non precision components), does have multiple uses, its cheap, and you can get it anywhere. Probably because it is a solvent, rust prevention, and water dispersant etc etc.
One of the more colorful stories I heard was WD-40 was a spin off of NASA and it was the 40th water dispersant trial hence the name WD-40. I don't know if its true but sounds good.
   / After the ball do you lube leaf springs? #6
It is not good on guns either; it will leave an ugly yellowish residue. that is hard to remove. I don't know to this day, why my Dad did that to a .22lr rifle. Nasty...
   / After the ball do you lube leaf springs? #7
bialecki said:
Their web site claims that WD-40 is a lubricant Welcome to WD-40 * Our Brands: WD-40 Product Information
Well if they have changed their advertising...so be it...but I WOULDN'T USE it as one...I use it for what it was designed for...a water displacement agent and a degreaser...and for that it does an EXCELLENT job...:)
If you read their FAQs...
How is WD-40 different from 3-IN-ONE?
WD-40 is the ultimate multi-purpose problem solver. WD-40 cleans/degreases, penetrates to loosen up stuck parts, prevents corrosion and is a light lubricant. 3-IN-ONE, with it's special drip spout, enables you to lubricate without any overspray or splatter. 3-IN-ONE is ideal to use on tools, rollers, hinges, in-line skates, wheels...nearly everything that moves.
They compare it with 3-IN-ONE?!?....I don't recommend 3-IN-ONE as a major lubricant either...:)
I notice they use the term LIGHT LUBRICANT...I wonder what they mean by that???:)
   / After the ball do you lube leaf springs? #8
It is also a desert topping and a floor wax! - Saturday Night Live sometime in the 70's, showing my age here;)
   / After the ball do you lube leaf springs? #9
schiker said:
WD-40 is not my favorite by any means. It tends to gum up precision stuff QUOTE]
since the guy was asking about using it on leaf springs
   / After the ball do you lube leaf springs? #10
That's a new one on me, Robert. I've used WD-40 on guns for over 40 years and never seen any yellowish residue. About 40-41 years ago, many police departments got a bulletin warning against spraying WD-40 on ammunition. The claim was that some officers had ammunition that failed and it was determined that the WD-40 had penetrated the seal between the lead and the brass, wet the powder, and caused the failure. I don't remember where that supposedly happened, so I don't know it to be a fact; only that such a bulletin was widely distributed in my department.
Kawasaki NR (A50324)
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
