Oil & Fuel After fuel filter replacement, PRIME with built-in pump
   / After fuel filter replacement, PRIME with built-in pump #1
John Skull
South Carolina
Kioti CK2610H, John Deere D130
The 'awesome' manual (CK2610hst) fails to prominently mention that there's a manual primer pump atop the fuel filter that should be pumped, preferably with the thumbscrew (just below it) removed. Sure does help after a fuel filter change where all kinds of air gets into the system. :banghead: Good thing we have TBN to overcome the lack of vital information. See pic..
   / After fuel filter replacement, PRIME with built-in pump #2
I have always filled the bowl before reinstalling.....keeps air out of system
   / After fuel filter replacement, PRIME with built-in pump #3
I always prime the filter, by filling the filter full with diesel, before rotating and tightening the filter into position. This way nothing else needs to be done....and I have not allowed air into the fuel system.
   / After fuel filter replacement, PRIME with built-in pump #4
I have found the primer pump pretty poor on my NX. Pumped at least 100 times with no fuel coming out. I fill the filter with fuel then put it on. That way it fires up right away.
55-Gallon Drum of Komatsu Hydraulic Oil HO 56-HE (UNOPENED) (A59076)
55-Gallon Drum of...
VACUUM PLANTER PLATES (A52708)
VACUUM PLANTER...
2010 BMW 328i (A56859)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
DRAFTING TABLE (A58374)
DRAFTING TABLE...
Electric Utility Cart (A56857)
Electric Utility...
