After 7 years, my original 4120 battery has died
   / After 7 years, my original 4120 battery has died #1
jtfx6552
West Chester, Pa
John Deere 4120
What should I replace it with?
I was happy with the way the original lasted, should I get another one?
   / After 7 years, my original 4120 battery has died #2
I am a big fan of Interstate batteries myself.
7 years is pretty good for a deere battery.
   / After 7 years, my original 4120 battery has died #3
I've had good luck and bad luck with Deere batteries. Some seem to last 8 years and the next one you're lucky to get 4. Had a couple Exides last 11 years in a L-8000 once.
   / After 7 years, my original 4120 battery has died #4
I have a Sears Platuim in my truck going on 7 years old and still cranking my v10 just fine.
   / After 7 years, my original 4120 battery has died #5
i got 10 years out of my last deere battery. Why wouldnt you stick with something that has treated you well
   / After 7 years, my original 4120 battery has died #6
As with everything else, what was good 10 years ago, doesn't mean it is good now.
   / After 7 years, my original 4120 battery has died #7
   / After 7 years, my original 4120 battery has died #8
What did you do to get 10 years of use out of it? Do you keep a trickle charger on it when not in use?
   / After 7 years, my original 4120 battery has died #9
I went to Optimas on everything I have. Once the original OEM battery goes bad, an Optima goes back in its place. Have had SUPER great luck with Optimas. Cost a little more, but seem to go alot farther, at least in my experience.
   / After 7 years, my original 4120 battery has died #10
I use Odyssey or DieHard platinum (rebadged Odyssey) for my equipment where I need the highest dependability and longer storage times. Optimas' had problems for a few years with higher than normal failure rates but that has been awhile and hopefully they have resolved those issues. I have over 30 batteries to maintain and can't afford for all of them to be the best. For something that is used and recharged frequently such as a daily driver most less expensive batteries will work well for you. Things like a boat or camper needing deep cycle and longer storage intervals I prefer the agm Odyssey. So I have Walmart batteries in my trucks, about $80 each and Odysseys' in my truck camper about $250 each. For most frequent use applications that is simething you use a couple of times a month or more you can get by with almost any brand.
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
FAKE (A52472)
FAKE (A52472)
Kubota BX2230D (A47384)
Kubota BX2230D...
