advise want to change ag tires to r4 dk45se
   / advise want to change ag tires to r4 dk45se #1
case310350
Like to change the ag tires to r4's I think I also need to change the rims. I would just go with r4s in the front but don't think the ratio would be right. Not easy
   / advise want to change ag tires to r4 dk45se #2
Your owner's manual should show all the options.
   / advise want to change ag tires to r4 dk45se #3
What is your reason/goal? Why are you thinking of changing and what do you hope the result would be?
have shop manual but not owners manual. tractor chews up the ground, turf. ground is soft here until july. leaving 4 inch troughs. have anther tractor with turf tires about the same size, 0 damage.
   / advise want to change ag tires to r4 dk45se #5
View attachment EX45 Tires.pdf
The above link will download the relevant page from the EX45 shop manual that shows all the tire options. I believe the DK45SE is the same but check to see if it agrees with your current AG tires/wheels.
   / advise want to change ag tires to r4 dk45se #6
I was considering getting industrial tires on the front of my tractor and Ags on the back and I believe those two front options happened to be the same diameter.
I'd think a turf tire exists that would fit on the Ag rim that would be close enough to use the Ag rear tire. The front tires are over geared a few percent (3-7% I think) so its not like matching tires on a 4wd road vehicle. You would have to be careful running two different tire types and on my hills I'm glad I have the Ag fronts when it greasy on a slope.
John Deere 4600 (A53317)
John Deere 4600...
1" Pneumatic Impact Wrench (A59076)
1" Pneumatic...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2004 GMC Sierra 3500 (A55973)
2004 GMC Sierra...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
