Front-End Loader Advise on how to power a loader on my Massey 188
   / Advise on how to power a loader on my Massey 188 #1
metal manny
Mpumulanga South Africa
Massey Ferguson 188
Hi all
I have a Massey 188 and would like an experienced opinion on how to power a loader. I understand that I can use the existing 3-point pump via a diverter/spool valve setup, but my concern here is that the articulation will be horribly slow as this pump, I believe, has plenty pressure, but a slow rate of flow?
If this be the case, then I will need to fit an auxiliary pump and reservoir and wonder what rate of flow in gpm/lpm would be ideal. Also where could I best source the power - off the crank pulley via a single/double vee belt drive, and will this be adequate to avoid slippage and squealing? My engine (Perkins A4.248) already has a brand new power steering pump occupying the geared output which, otherwise would have proven perfect for this application.
I have very good mechanical and fabrication skills and well understand the principles of hydraulic systems, but have zero knowledge of how to correctly select and match non-standard components to achieve a satisfactory result.
Any one with knowlege of hydraulics' opinion would be most appreciated.https://cdn-0.tractorbynet.com/forums/images/smilies/2/thumbsup.gif
   / Advise on how to power a loader on my Massey 188 #3
Yeah, 11gpm is plenty for a FEL. Besides, how often will you be using both, the 3ph and FEL, at the same time? :confused2: My Ford has a valve/spool combo to divert flow to either or both my 3ph or the rear remotes and any where in between. :dance1:
OK thanks i7win7 and Tinhack. That will be perfect and save big $$$! I doubt I'll ever use the 3PH and the FEL simultaneously - way above my pay grade, LOL!
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
Year: 2011 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 249,866 Plate: Body Type: 4 (A55852)
Year: 2011 Make...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
