Buying Advice Advice wanted BX or ZD machine
   / Advice wanted BX or ZD machine #11
I'd vote the BX, use it to help build a larger shed, then get the ZD also.. :D
Seriously, you will use the FEL a lot more than you think. I don't know how I survived without one. I mow with 6' RFM, and have been thinking of getting a husqvarna for my son to use. With all the Zero turn chatter on here, now i'm pricing them instead :rolleyes:
   / Advice wanted BX or ZD machine #12
I have both & would say the ZTR is over kill, unless you are the extreme type & then who cares about over kill,...The ZTR are so very fun to mow. BUT...They are a one trick pony & that is it. I would think a sub compact would be a nice helper to have & mow's to boot. The most used gear on my 5.8 acres is my 13-15 year old JD lawn trators lx172& lx176, point a.b. pulling small wagons with sprayer, chainsaw gear, brush, etc, etc// reason, they are light. I can only put my ZTR & tractor on the ground after May of each year if I am lucky without damged to lawns & such. ruts & more ruts if I get to itchy to do tractor work,of course which I have & payed the price. I would get the BX . If the extreme type ,both are supreme.
Joe
   / Advice wanted BX or ZD machine #13
I had a commercial ZTR and a BX. I sold my ZTR and got a MMM so I would have one machine and get more use out of the tractor. The BX mows ok, but with lots of stuff to go around takes time. My ZTR with a 48" deck took half the time that my BX takes with a 60" and the ZTR did a better job. Try a walk behind ZTR with a sulky. They cost less and are a blast to ride and are even more maneuverable than a rider. The BX gives you everything in one package and will do a good job. The ZTR would be my choice for mowing, hands down.
   / Advice wanted BX or ZD machine #14
i think you're on the right path --
-- but my whole world became a lot easier when i got my zd331 this year, taking a 3 acre lawn to mowing in just under an hour.
i got a backhoe for the b2400, so it is used primarily for heavier work, and i have the RTV for the hitch-work.
it's all about time saved, for me -- the zd is a lifesaver.
   / Advice wanted BX or ZD machine #15
I've recently sold a tractor that I could pull an aerator and dethatcher behind and I wonder if I'd miss the utility of the tractor if I bought a zero turn machine. Don't know what attachments are available for zero turns.
Basicly none.
   / Advice wanted BX or ZD machine #16
When I bought my BX a little over a year ago, I thought I would give up alot on the quality of the cut, but that is not the case. I have a 60" MMM, which is not the fine cut, but I put the mulching kit on it. The only drawback is the BX is pretty heavy compared to a regular riding mower, so it does seem to mash the grass down a little worse. The biggest suprise I have had with my BX is how much I use the FEL. I have put about 200 hours on my machine in the first year, and about half of that is FEL use. I use mine to haul my splitter to the trees I have cut down, and then haul the split wood to the pile. Plus I have moved dirt, dug out some stumps and many other things.
I also bought a rear blade for mine and haven't used my snowblower since, but my drive is about 600 feet long.
I don't think you would be disapointed with a BX as far as mowing goes and you will really enjoy having the FEL.
   / Advice wanted BX or ZD machine #17
Faced with almost the exact dilemma, I chose the BX and BOY am I GLAD that's how I went. I mow a little more than 1 acre of heavily wooded grass and can get it done (including bagging) in about 45 minutes (that's tractor time...not trimming and such). Perhaps I could get that down to 30 or even 20 minutes with a ZTR, but along with gaining 15 to 25 minutes of my life, I'd lose one of the best tools I've ever purchased. I do EVERYTHING with my BX and the mow quality is exceptional.
Alternately, my cousin mows 5 acres of open field every week. That's his yard. His Kubota ZD21 FLIES and gets the job done much faster than a BX would. In his case, he's much better with a ZTR and a non-mowing B21...the exact solution he's deployed.
If you're looking for one solution, go with the BX. I hate renting things. Don't like the timetable it puts on my projects. You'll gain little time in mow speed and give up HUGE amounts of utility.
To give you an idea of how quickly a BX could dispatch 10 yards of mulch: I trailered my BX to my parents house (~3 hours away) to help fix their 1/2 acre yard. After I completely re-graded their ditchline and cut/filled numerous places in their yard (as much as 1 foot in places), I spread 6 CY of screened topsoil and 6 CY of compost blend. I evenly spread and graded that 12 CY of material in about 1 hour. I completed the entire lawn rehab job (including many, many other tasks) in 1 day. The next day, my Mom asked me to get the roots out of the back yard. Using the backhoe, I pulled ~1,000# of roots out of the ground and regraded the back yard for grass planting...that distraction took about 5 hours start to finish.
The BX is wicked-amazing.
   / Advice wanted BX or ZD machine #18
I replaced my BX2200 with a BX2660 six months ago and it mows everything without needing a second mower. We have a push mower that hasn't been used in so long it no longer runs. We also kept a JD425 to use in "trimming" and it has the same flat on it that it has had for about a year and it hasn't been started this year. The BX is a very nimble machine and will surprise you how sharp it will turn or how quickly you can do a 3 point turn with the HST.
My vote would naturally be for the BX with the 60" MMM. I prefer the standard deck as I have had a "fine cut" on a JD and unless the grass is completely dry you will probably get a lot of caking under there and spend a lot of time digging it out. The quality of cut on my 60" MMM is very good with "windrowing" only in really wet or tall grass.
   / Advice wanted BX or ZD machine #19
OT
Erici just checked your site out, how wonderfull. i have had no less than 5 APBT's in the last 30 years. There are all treated as kings & queens
Jax
Rosie
Kauss
Angel Baby
Clover
sorry for OT'ing this great thread
Joe
   / Advice wanted BX or ZD machine #20
The right answer is the right answer based on your specific needs and wants. From what you described the BX is a more plausible direction than a dedicated ZTM.
If space is a premium and your really are looking for a all in one machine the BX would be the way to go - my former BX22 with a 60 inch cut cut like no other tractor / lawn mower I ever operated however, I was not happy about the fact that I had to take the MMM off ever time I wanted maximum clearance (i.e. wood, skidding logs etc). Since I mow every weekend I found myself taking the mower on and off a lot and for me it was a PIA. I vowed that if I ever upgrade I would look at a dedicated ZTM machine (I also have a 36x30 barn so space is not an issue).
I recently pulled the trigger on a B2920 and ZD21 (used w/ 144 hours) - even though its way overkill for my 1.5 acres I justified it by thinking that this would be the last mower I will ever buy (I also use it at my other property ~2 acres) and I could use the tractor all the time as a tractor (I put on ~100 hours / year in tractor mode). For me this was a great move and I have not looked back. My only problem is my 86 YO Dad will not let me cut the grass since he is having so much fun. :mad:
Good luck!
2002 Bobcat 753 Skidloader (NOT RUNNING) (A50774)
2002 Bobcat 753...
2007 Brunswick Challenger 27ft Fire Rescue Boat with Tri-Axle Boat Trailer (A50324)
2007 Brunswick...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2005 Toro Workman 175 Sprayer Cart (A50322)
2005 Toro Workman...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
