Advice on wheel weight brackets?
   / Advice on wheel weight brackets? #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Hi Folks:
I'm thinking of making some sort of bracket to hold barbell type weights on the rear wheels. I'm thinking a simple triangular shaped plate plate with a bar sticking out perpendicular to hang the weights on would be ideal. A couple or three 50-lb weights on each side ought to be good. The price is attractive, they're about $0.20-0.30 per pound (cheaper if you buy them from a person rather than a used fitness goods store).
One question: my rear wheels have six mounting bolts. Would it be better to make the triangular plate such that I take 3 of the bolts out, put the plate on, then put the bolts back in? In this case, the bolts holding the rim to the hub would be maybe a 1/4" or maybe a little more short of the depth they had before. It looks like there's an 1/8" thick washer between the wheel lugs and the rim now, so I could remove that.
OR, would it be a better idea to just drill 3 holes into the rim and mount the triangular plate that way? I would drill outside of where the hub is, but not to where it does into area of the wheel that holds pressurized air, of course. I doubt three 1/2" or so holes would substantially weaken the rim, right?
Dave
   / Advice on wheel weight brackets? #2
Dave if it were me I would opt for removing the washers and installing the triangular shaped support. Not keen on drilling any extra holes in any rim. Just be sure that you re-torque the wheel bolts after you reinstall them per your operators manual and I think you'll be good to go.
   / Advice on wheel weight brackets? #3
Dave,
Doesn't the MF 1220 have any accessory holes in the wheels?
</font><font color="blue" class="small">( Dave,
Doesn't the MF 1220 have any accessory holes in the wheels? )</font>
Nope...no accessory holes, just the 6 bolt holes for attaching the wheel to the hub.
Dave
   / Advice on wheel weight brackets? #5
Does the wheel have flat pressed areas on the disc?
</font><font color="blueclass=small">( Does the wheel have flat pressed areas on the disc? )</font>
I had to go look. Actually, no. Looks like the wheel is just the cylindrical piece that the tire seats on with a flat round plate welded into the middle of it, in a nutshell. It appears to be a single flat plate without looking too close. Seems like it ought to be alright to just drill 3 or 4 holes in it....
Dave
   / Advice on wheel weight brackets? #7
I was hoping that there was some flats for you to drill. I don't think that you would hurt anything by drilling your own holes.
   / Advice on wheel weight brackets? #8
My old fords have lots of extra holes drilled for weights.. no rim failures yet!
Soundguy
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
2015 FREIGHTLINER M2 DAY CAB (A52141)
2015 FREIGHTLINER...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
