Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower?
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #31
I agree with the OP, the Husqvarna gt52xls that he inherited with the property is fine for doing the bulk of the mowing for a season or two. Or at least until he gets a feel for that chore.
For the tractor, nobody never really understands what a good thing a compact tractor is on a small acreage until they have one. I'd concentrate on a good name brand - Kubota is excellent - with a loader and in the 35 to 45 hp range. No cab, 4wd, universal tread, nice loader with extra front hydraulics plus oneset of hydraulic remotes on the back, and a standard 5 foot pull type brush hog mower. All of that will do 90 percent of the jobs, will retain more than 90% of the value, and can be traded or added to after you get a feel for the property.
You don't need to get everything at once. Tractors are univeral platforms. Get any good one and you can always add to it.
If you want to really treat yourself on uneven terrain, consider one of the Kubotas with the optional HST Plus (HST+) auto load-compensating transmissions.
luck,
rScotty
rScotty, you mention a "standard 5 foot pull type brush hog mower". When you say brush hog, do you mean something heavier/stronger than a finish mower? I've been looking for a pull type 5' or 6' bush-hog type mower (lot less stress/vibration on tractor than 3-point hitch models, imho), for use behind a JD 2038R, with no success. I have a 6' finish mower I use for clipping hay field after season, but don't want to abuse it mowing small trees, bushes, brush, etc. Any suggestions where I might locate something more suitable? Thanks in advance.
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #32
It’s a budget killer but, here’s a ZTR for hills;
It’s a Cub Cadet Pro Z 560 s KW and runs around $12K. It’s built like a tank and mows hills quickly and safely.
Mike
I'm sure it works fine, but I've slid sideways a lot with those tires. For hills, I recommend a much more aggressive tire.
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #33
Are you referring to those tires mounted to a standard lap-bar steering ZTR? Then, yes, those tires will slip and slide on hills, including on my property during several ZTR demos.
However, if you believe the performance of those tires are the same on the Cub Cadet PRO Z S model equipped with a steering wheel and 4-wheel steering, you’re mistaken.
These tires do not slip or slide on the Cub Cadet which is the reason I bought it over all other ZTR options.
Mike
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #34
I use the large Kubota Zero Turn mowers (ZD331 & ZD1511 - 60" rear discharge decks) on very hilly Virginia property for the most part. They out-mow the L4400 (Kubota tractor with 6' Bushhog) by a wide margin as long as the grass isn't over 14". Just don't bother with turf tires. I use Carlisle WT300 and even better Carlisle VersaTurf on the zeros. This vastly improves their capabilities on hills. If you are navigating VERY steep hills or have tall brush or unseen holes, the tractor wins. If you have flat spots at top and bottom, mow up and down the hills. Even with spacers the L4400 is less stable than the MX6000 (same body as MX5400), though I also added spacers there. The L4400 wants to overheat under heavy grass and going up the very steep sections. The MX6000 has no problem at all.
I recommend getting aggressive tires on a heavy duty zero turn mower to try first. You will continue to use it for many areas regardless. Then get a tractor - so handy with the loader (and hopefully plumbed for a future grapple) you'll wonder how you went without. I use a Woodmaxx 9000 chipper and it runs fine on either tractor and does an excellent job reducing tree piles to fine chips - perhaps an important fire reduction tool for your area.
If you eventually go with a tractor, I recommend filled R1 (Ag tires) for best traction.
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #35
Others know more about the equipment... Here are a few critical tips if you've never run a tractor and are the sort of person who can go to school on other people's mistakes:
Be super careful operating front end loader on hills, it is easier than you think to turn a machine over and a raised loader changes center of gravity substantially.
If you are mowing dry grass with lots of chaff check the radiator screen often and watch the temp gauge like a hawk. You can overheat and burn an engine up pretty quickly if radiator is plugged.
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #36
The neighbor was mowing a couple acres of grass next door.
The dandelions where thick and the blossoms were in seed.
I saw him stop and get off his massey135 and walk around it cursing.
Being curious and just a bit nosey I went over to see what was happening.
"Piece of s--t useless garbage tractor..." :F---ing thing is overheated again"
I asked if I could take a look.
Opened the front grill cover and the rad was packed with the white fluff from the dandelions seed.
Not just some, but like someone put a full pillow in there. It came out in almost a single lump.
Told him to start the tractor and the temp guage went to normal almost immediately.
Tough little tractor. By all rights it should have warped a head or some such damage.
Nick was like that, zero maintenance and bitched about the quality of something when it failed.
He refused to grease things because it made them dirty.🙄
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #37
My Kubota dealer was adament that a PTO chipper is a horrible idea for and tractor. He did sell me a nice L3560- cant recommend the Grand L's enough. I'm working 7 acres of woods with some wet areas.
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #38
I went down about the same path as you 10 years ago
Bought 10 acres, 4-5 meadow, the rest woods.
I wanted the Kioti CK35, wife had me get the DK45, ballast of the bigger machine made the biggest difference.
First purchase was grapple, best thing for a tractor.
Build a 3pth counterweight, it’ll do wonders for your loader work.
Mowed with a 6ft rear finish mower for Years 2-6, Exmark 60” zero turn ever since. Tractor was slow, used more fuel, didn’t handle sharp turns as well, but it was fun! ZT was 1/2 the time, way more maneuverable, and more comfortable, it’s kinda fun too!
Getting one machine to do as much as possible was what i started out moving toward, but realized you need more than 1.
For hill mowing (which i do commercially), the ZT, stander, or walk behind is always better for me. Commercial mowers are really different (and more expensive) but to me it was night and day.
When it comes to trees and brush, my DR walk behind brush hog is unbeatable, more work than the tractor, but what it can do and where it can go is amazing.
I borrow a chipper when I need it, but I would rent one before buying one, as it would add to the many implements that are sitting out there rusting (one project tools: back blade,York rake) but they are all sellable.
my advice is buy as much tractor as you can, 4WD or nothing, get a better tires for your ZT or get a walk behind or stander for areas where the ZT isn’t good. I’d rent implements that are rare usage (chipper,etc).
But….
start looking at grapple videos, it’s amazing what you can do with one.
good luck, and it didn’t happen without pictures!
MT
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #39
   / Advice on tractor for 7.5 acres - Mowing pasture and general use - L3902? What flail mower? #40
Well I paid 32K delivered for the tractor in my profile over der <------ with a 72" rotary mower and filled tires. Its a beast at 52hp - you will learn quickly how to drive on hills. Inna tractor the seat sits pretty high up so your comfort level will be slow going until you figure out your not going to tip over.
We also have a 52" ztr mower for the weekly grass we cut. Its not that great on a hill most tractors aren't you gotta figure out how to do it safely.
Your 4-8 cuts a season is probably closer to 4-5. Get a rotary cutter and you can make hay when the sun shines all day long.
Can also think about getting a roto-tiller for a garden - good ones are 2-3K$
Also can seed the really hilly spots with wild flowers and then just cut 1x in spring and 1x late fall (or not). Make it easy on yourself, cutting a field 8x a year is basically cutting grass.... let it grow and just finish cut where you need to. Typically around these parts we cut around the fields finish height about 6-10 feet (2-3 passes) and let the center of the field grow to hay and cut with rotary mower.
Also maybe there's a farmer around close by that likes to grow hay. If its an easy cut they might help there but onna hill meh.
Plus 2 on Woodmax products. Can get a 3pt hitch chipper and take it with you and/or do burn piles.
Another implement to think about is a grapple. GREAT for brush management and picking up tree debris.
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2017 Jacobsen Greens King IV Plus 62in Reel Commercial Mower (A56857)
2017 Jacobsen...
DOOSAN  G25 GENERATOR (A58216)
DOOSAN G25...
Husky Aluminum Truckbed Toolbox 21" x 70" - Diamond Plate (A59225)
Husky Aluminum...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
Deere 331G (A53317)
Deere 331G (A53317)
