Advice on lubricating hydraulic ram
   / Advice on lubricating hydraulic ram #1
nykyfyr
Lake George NY
Kubota B2710
When I store my equipment I always try to store the hydraulics with the ram closed. On my Kubota, I won't be able to do this on the FEL or backhoe. Anyone know of a good product to use on the ram to prevent it from rusting?
Thanks!
   / Advice on lubricating hydraulic ram #2
use the old fashioned method..... smear it with chassis grease. It is important to get it well covered especially where the ram comes out of the tube.
   / Advice on lubricating hydraulic ram #3
I've been using lithium grease, cause I have it on hand. I just smear some on with a rag. I've wondered about the o-rings on the rams, I assumed they were to prevent the orange paint from getting into the cylinder. I think that I should slide the o-rings back down to the cylinder so that amy dirt stuck in the greases will get pushed out of the way. Anyone have thoughts on this?
Lou
   / Advice on lubricating hydraulic ram #4
In my 40 years of operating heavy equipment.I have never seen a ram rust. on big backhoes. The oring should go back.
   / Advice on lubricating hydraulic ram #5
I have seen rams rust many times. It is a matter of the quality of the ram. My Fischer snow plow rams have rusted as well as the rams on my 1964 Minneapolis Moline Backhoe & Loader. Both of these pieces of equipment had rust on the rams before I purchased them, so I have no idea as to how they were stored. Grease is inexpensive, so I can see no reason not to cover them as a precaution.
   / Advice on lubricating hydraulic ram #6
just load the grease on, should not be a problem.
Great, grease it is!
Thanks.
   / Advice on lubricating hydraulic ram #8
junkman good idea to cover them.I have never had anything small to look at.My tractor is the smallest thing I have with rams on. Probably got better quality rams on heavy equipment.
2020 Bell TC-11A Crawler Carrier (A52384)
2020 Bell TC-11A...
2014 TROXELL 130 BBL VACUUM TANK (A53843)
2014 TROXELL 130...
2009 Ford F-550 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2009 Ford F-550...
2013 RAM 4500 (A50323)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
