Advice on locating missing survey pin?
   / Advice on locating missing survey pin? #21
Are aerial photos available at the county? Our county has the property lines drawn on aerial photos. If your county has these photos that should get you close to the corner to look for the pin.
Later,
Dan
I was just thinking the same thing. When we lived in Maine our boundaries of long ago were easily identified by old Soil and Water Conservation aerial soil maps. Boudaries often followed soil types and I'll bet you have some hidden rock walls in there as well. Ours was interesting because our wooded portion was all fields long ago. You might look at your "Property Abstract" that is part of your legal paperwork and shows every transfer of property. Ours started with John Admas and the split from Massachusetts and went forward. Interesting reading if nothing else.
   / Advice on locating missing survey pin? #22
Dodge Man may have a better answer, but a stake (with hieroglyphics on it) is a temporary marker used by surveyors, not a permanent marker.
   / Advice on locating missing survey pin? #23
Thanks to all. I'll try the metal detector and then maybe hire a pro. The original survey is from 1909 and seems quite precise. Distance from both known pins is about 650' through deep woods. There was a stake. I know about where it was but a few years ago the stake was pulled and a new one appeared and the change was in my favor... I suspect neighbor #3. That stake is gone now too. There is currently no action to sell or divide that I know of but I'm thinking about starting a timber stand improvement plan and don't want to cut anything that isn't mine.
Given the circumstances, I'd hire a surveyor. 100 years ago your line was done with a steel tape and a staff compass... even my hand held compass is more accurate than what they had then. Have it done right, maybe record it at the registry, and be done with it.
What kind of TSI are you planning? Make sure you take before and after pictures, 20 years from now you'll be glad that you did. :thumbsup:
One more suggestion, since your pin seems to have a gypsy spirit; once it's set properly find a pipe big enough to slide over it: engrave or braze your deed book and page# on it, and drive it down below the soil surface. To make it easier to locate later, attach a piece of refrigerator magnet to it. That will drive a ferrous metal detector crazy... back in my mortgage inspector days I once dug down 1 1/2 feet thinking I would find a pin; only to find a piece of magnet the size of my thumbnail.
   / Advice on locating missing survey pin? #24
Just had my place surveyed (by a TBN member) and gained 6/10ths of an acre :thumbsup: LOL
One of the old pins they found was 30' from where I was searching with a metal detector. I had crudely plotted it out with ExpertGPS using two known pins. One was a section corner mushroom cap type.
   / Advice on locating missing survey pin? #25
I used to know where one of our pins was, even flagged a shrub above it. Went looking for it a year ago and can't find it. Measured off another corner along the road & still can't find it. Tried a metal detector and got a lot of false indications and didn't find it.
Going to measure again. Also might be able to find a pin on the other side (the far corner of the neighbor's) and the missing pin should be in line roughly half way between the two known pins.
   / Advice on locating missing survey pin? #26
sometimes i gotta wonder. GPS is getting so much better these days for accuracy. and you can look up in a "PLOT" book, i normally get a new one in mail each year free of charge. for coordinates.
i suppose though. the coordinates are from a certain "height above sea level" and need to be adjusted for a given height or does GPS do that already?
   / Advice on locating missing survey pin? #27
GPS in general isn't very accurate for elevation. The ones surveyors use may be an exception. Google Earth isn't very accurate for elevation, either.
   / Advice on locating missing survey pin? #28
I know distances and directions from two pins that converge on a missing point. The terrain is to rough to pull a tape and I'd like to mark along the lines. Seems like a good GPS might solve my problem. Any how-to advice or on affordable systems or places to rent? Thanks in advance.
Put new blades on the finish mower. Works for me, unfortunately, every time.
   / Advice on locating missing survey pin? #29
I've gotta say, if my neighbor came to me and asked for my help locating a pin, I'd politely decline. As my father likes to say, "Great minds think alike. So do dumbasses." Just because me and my neighbor find a spot and both agree that's where the pin ought to be, doesn't mean we're likely to be correct. If the change is in my favor, who's to say years later, somebody doesn't find the "real" pin and start trouble after I've put up a fence or something. And if the change is in his favor, you darn well better believe I'm not going to trust it until a licensed surveyor puts his stamp on it. So, at the end of the day, we can sit around and opine as long as we want about where we think the pin is or ought to be, but if you need to know for sure, you've just got to hire a surveyor. And that goes double if you suspect that someone has been moving markers around.
BTW, if the issue is logging the property, perhaps you could side-step the question of where the pin is located by getting a signed document from your neighbor giving you permission to log up to a certain line. That way, if it's your land, it doesn't matter because it's yours, and if it's your neighbor's land, it doesn't matter because you've got permission. Just a thought.
   / Advice on locating missing survey pin? #30
I've gotta say, if my neighbor came to me and asked for my help locating a pin, I'd politely decline. As my father likes to say, "Great minds think alike. So do dumbasses." Just because me and my neighbor find a spot and both agree that's where the pin ought to be, doesn't mean we're likely to be correct. If the change is in my favor, who's to say years later, somebody doesn't find the "real" pin and start trouble after I've put up a fence or something. And if the change is in his favor, you darn well better believe I'm not going to trust it until a licensed surveyor puts his stamp on it. So, at the end of the day, we can sit around and opine as long as we want about where we think the pin is or ought to be, but if you need to know for sure, you've just got to hire a surveyor. And that goes double if you suspect that someone has been moving markers around..
That's where you and I differ. If I'm happy with what we agree upon and new deeds are registered accordingly; I don't care what happens years down the road. Any agreement I made would be based on what the original deeds describe anyways; and unless there was already a good metes and bounds description on both properties the lines are going to be based on the surveyer's expertise and interpretation. I've seen hard feelings over that too.
I would never agree to that if I was the neighbor. When I'm laying out a harvest block and can't determine where the line is, I stay completely away from where the line might be. I'd rather leave a little wood than take a chance of a timber trespass. Not only is that too expensive; but neither I nor my employer needs that kind of reputation.
LOOK! (A50657)
LOOK! (A50657)
2019 Komatsu PC490 Hydraulic Excavator (A49461)
2019 Komatsu PC490...
Wacker Neuson TH522 Telehandler (A50860)
Wacker Neuson...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2012 Ram 3500 Crew Cab 8FT. Flatbed Truck (A48081)
2012 Ram 3500 Crew...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
