Advice on How to reduce slope on dirt roads
   / Advice on How to reduce slope on dirt roads #41
I took out the crest of this hill and deposited the material on the awning side of my newly built barn. I cut 2’ out of a 100’ section with an L2501 utilizing the box blade.
   / Advice on How to reduce slope on dirt roads #42
It is amazing what can be accomplished with small tractors.
I built this 450 foot road section with nothing but a 27 HP Kubota Tractor.
I dug the ditches, put in the sub-base, hauled in the 350 cubic yards of surface gravel from my gravel pit 1/2 mile away, and even installed the rock check dams for erosion. This was only a 9% grade, but in the end it passed inspection as a Heavy Haul Road by the Federal Government (USA).
It is surprising what can be accomplished with patience and proper use of the equipment at hand!:thumbsup:
   / Advice on How to reduce slope on dirt roads #43
I will share a story.
When I was in college my first love was the daughter of a guy who worked for the Canadian Government. He was a member of an exchange trip between Canada and China. This was in the early 1970's before the US had established relations with the US. The group was invited to see the construction of a large dam project. There were over 10,000 men with wheelbarrows moving dirt and fill. One of the Canadian members was a heavy equipment supplier hoping to make some sales and he told the Chinese he could do the work of 10,000 men in a couple of days. The Chinese fellow heading the meeting said the equipment would require capital they did not have, require maintenance and spare parts from North America. But they had plenty of people who needed work, labor was cheap, and they had plenty of time.
I am one of those posters who is guilty of "doing it efficiently". Part of that is my training (engineering), part is my age, and part is laziness.
In this case, I would hire the work out....BUT IT IS NOT NECESSARY! Even a small tractor is much better than a wheelbarrow.
As in most threads, we put our values into the recommendations we make. And we think the way we did, or would do, a job is the best way. Even if it is the best way, it is not the only way.
   / Advice on How to reduce slope on dirt roads #44
For those of you who say that a tractor is not for building roads,Please don't come sneaking around here and tell my B7800 that.My little tractor has built and maintained miles of road with no problem. It's not the tractor without the ability, it's the operator.
   / Advice on How to reduce slope on dirt roads #45
I love the check dams.
   / Advice on How to reduce slope on dirt roads #46
Hello All,
I just bought a Bx2680. My first urgent project is to reduce the slope on a dirt road/trail that runs from the front of my 11 acre property down to the river. There are two drops. The first one is about 30ft drop and the second about 20ft. The slope on both is very high. Eventually, I want regular 2WD SUVs and golf carts to be able to easily go up and down. Right now, my KIA 2WD SUV barely makes it up either slope. I want to start using the front loader to start shaving the dirt in the steep sections and reduce overall slope. I'm thinking around a 25 degree slope might do the trick. It is all dirt and not too hard so I'm hoping the front loader does the trick. My question is: Do I need to get the front loader blades even for pushing just dirt? ARe the other tricks or other attachments I need? Thanks!
Has anyone answered his question? I can't because I've never dealt with multiple front loader blades and don't know what "get them even"means.
   / Advice on How to reduce slope on dirt roads #47
Hello All,
If the question is "should I tilt my bucket 90 degrees to turn it into a dozer blade to push just dirt?", the answer is a resounding NO. That is a good way to bend hydraulic rams. The better question was the second one - Are there other attachments he needs? YES - a BOX BLADE!
   / Advice on How to reduce slope on dirt roads #48
It's surprisingly amazing the yarns people can spin with an imagination and keyboard and the number of people who will readily tangle themselves up in them.
   / Advice on How to reduce slope on dirt roads #49
He’d bury a box blade with the loader.
   / Advice on How to reduce slope on dirt roads #50
Regardless of tractor size, the proper tool would be a box blade. Use it to shave material and move it. It will be so much faster and more productive than using the front loader (not to mention, the front loader is not really built to do what you want).
While a BX will take longer to do this job than the right size tractor, an appropriately sized box blade will be the most effective approach to the problem no matter what size tractor.
Yep - hit the nail right on the head. It can be done with some time investment. Box blade with rippers will break up the dirt, then drop it down the slope. Not real expensive for that size machine and will useful for possible future projects as well.
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A55787)
2017 Bomag BW90...
2008 Isuzu NPR-HD Landscape Dump Truck (A55788)
2008 Isuzu NPR-HD...
2013 Chevrolet Traverse (A53314)
2013 Chevrolet...
2012 Honda Accord Sedan (A55758)
2012 Honda Accord...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
