Advice on Gravely 1997 14G Professional Garden Tractor
   / Advice on Gravely 1997 14G Professional Garden Tractor #1
WICKSY44
Gravely 14G
I am new to this site and currently have a 1970 Gravely 432 Commerical direct drive. I'm considering purchasing a 1997 gravely 14G but don't know about all its specifics. Is the mower a direct shaft drive or driven by belts? I wanted to use my 40: direct drive off the 432 with it.
Also, I'm looking for a snow cab for the 14G; does anyone know if they made a hard top (metal) model in addition to the soft canvas?
Thanks in advance,
Doug
   / Advice on Gravely 1997 14G Professional Garden Tractor #2
Doug, the 14G is much like the 432. All attachments are shaft driven. The out front mower can be used on the 14G but the shafts are different from one machine to the other. You would need a different long drive shaft, the one under the tractor. A stub shaft that goes through the front axle and a different u-joint assembly that connects to the front adapter. All the things mentioned are expensive.
Roy
   / Advice on Gravely 1997 14G Professional Garden Tractor #3
And that is where the similarity ends. The G series is the culmination of the 800/8000 series. The 400 series is based on the two wheel tractor transmission. The 800/8000/G is a much larger transmission made specifically for 4 wheel tractor use.
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52705)
2015 JOHN DEERE...
